November 19, 2025, 02:21:41 PM *
Author Topic: timing belts  (Read 2037 times)
john
tyler texas
« on: July 06, 2009, 03:14:54 PM »
a question people ... if i may     coolsmiley
gates ... napa ... goodyear ... honda ...
whos timing belts are best ?
 are they all same same ... is one make better than others ?      Undecided
thanks for your time ...    cooldude
vrcc # 19002
« Reply #1 on: July 06, 2009, 04:03:25 PM »
I have installed many a timing belt and all kinds factory and after market. The factory ones are always so pretty and usually more expensive did it make any difference in the results, NO. Plus no one ever sees it except the guy that replaces it the next time if the vehicle is still around. I just changed the belts on my Valk and went to Napa and picked up theirs and they work fine. Quality was good nothing different about them so I really have to say that it doesn't matter. To do the job correctly is more important. The boxes that the belts come in are marked for Honda motorcycles just for additional info. My bike only has 40k on it and its a 01 and I was happy I replaced them it did make a difference in the smoothness and because the belts are new and not 8 years old were much softer and quieter than the old ones that had somewhat dried up.
« Last Edit: July 06, 2009, 04:06:08 PM by Robert » Logged
Bone
« Reply #2 on: July 06, 2009, 06:38:13 PM »
I installed Napa belts on a 85 Goldwing (4 cyl). Get the belts before you start the job. I was alerted by a post that most Napa shops carry one of each belt they keep in inventory. Go to two shops or my local Napa had the second belt the next AM.
« Reply #3 on: July 06, 2009, 06:38:23 PM »
changing them.. Don't let the pulley move at all, these can not be allowed to move at all..  Don't let me scare you, this is an easy job. Just make sure the timing marks are correct when your finished and turn the engine over by hand to make it turns freely before starting.. I also set the tension slightly looser than than Honda says,, I like 3/8",, that makes them a bit quieter..
Ferris Leets
Catskill Mountains, N.Y.
« Reply #4 on: July 06, 2009, 06:45:05 PM »
Part numbers for the napa belt?
Bone
« Reply #5 on: July 06, 2009, 06:57:30 PM »
This is posted in Shoptalk.
 http://www.jkozloski.com/generic_parts.htm
Lot of good info posted there including belt numbers.
