February 07, 2026, 06:06:46 AM *
Author Topic: Clutch Master Cyl assy same btwn Tourer and Standard?  (Read 1037 times)
rmcnelly
Portsmouth, VA
« on: July 13, 2013, 07:32:54 AM »
Need a clutch master cylinder assy for my '98 standard as the mirror ripped out the mirror mount threads during my wreck.  Was looking for used but discovered a new one for a '99 GL1500CT was only $78 here:
http://www.motosport.com/cruiser/oem-parts/HONDA/1999/VALKYRIE-TOURER-_-GL1500CT/CLUTCH-MASTER-CYLINDER
But when I look up the same part for a '98 GL1500C it has a different part number and is $300!
http://www.motosport.com/cruiser/oem-parts/HONDA/1998/VALKYRIE-_-GL1500C/CLUTCH-MASTER-CYLINDER
What would be different on the Tourer assembly?
--Rick
'98 Standard
Michvalk
Remus, Mi
« Reply #1 on: July 13, 2013, 07:53:27 AM »
Nothing different that I am aware of. cooldude
chrise2469
Winnipeg Manitoba Canada
« Reply #2 on: July 13, 2013, 08:04:28 AM »
I checked the honda direct line parts fiche and they list both 1500c and 1500ct as 22890-MZ0-006  @ $254.
It looks to me that this 006 part number is a newer part # for the same part.  I did a cursory google search to see if I could find a supersede  list but couldn't.
I also looked at a 2000 1500cf(interstate) and it has a different part number as well but internally is the same
All the internal components are the same if you compare the two of them.  I would order the cheaper one and save $200.
Hope this helps.
« Last Edit: July 13, 2013, 08:09:29 AM by chrise2469 » Logged
rmcnelly
Portsmouth, VA
« Reply #3 on: July 13, 2013, 09:45:49 AM »
Thanks guys,
I might be able to heli-coil the thing too.
--Rick
'98 Standard
Michvalk
Remus, Mi
« Reply #4 on: July 13, 2013, 10:28:47 AM »
Yeah, the interstate one is slightly different, because of the bracket for the radio controls cooldude
« Reply #5 on: July 14, 2013, 08:53:20 AM »
Thanks guys,
Yep, that and/or Pinwall would be my suggestion for the best things to try first.
rmcnelly
Portsmouth, VA
« Reply #6 on: July 14, 2013, 01:42:23 PM »
I didn't know about Pinwall, I'm searching there now.
 Thanks!
--Rick
'98 Standard
rmcnelly
Portsmouth, VA
« Reply #7 on: July 14, 2013, 02:51:02 PM »
Ran a die over the mirror stem threads and used my neighbor's thread chaser on the mounting hole and was able to salvage it!   Happy Camper!  :-)
--Rick
'98 Standard
