February 07, 2026, 02:56:53 PM *
Author Topic: Valk Quit Running  (Read 3870 times)
JamminJohn1
Tug Hill
« on: July 14, 2013, 11:05:14 AM »
I was almost home and the motor stopped making power.
NO mechanical noise.
The lights all work.
No blown fuses.
Good battery.
Now,when I hit the starter the lights dim but there is no relay click.
When I bypass the relay it turns over but doesn't start.
Yes,the kill button is on RUN.
The sidestand light goes on & off when I move it.
Idea's ?
Maybe corroded wiring harness plugs ?
           thanks,
                      John
Let's ride some more !
saddlesore
« Reply #1 on: July 14, 2013, 11:43:22 AM »
I'm not the expert here but have you checked the starter switch?
The switch has a tendency to gunk up and needs to be cleaned.  The tech board may give you the directions.
http://www.valkyrieforum.com/bbs/index.php?action=search2
I had the problem and cleaning the contacts inside the switch cured it. You might want to bend the contacts up a little bit too.
DARE TO BE DIFFERENT
« Reply #2 on: July 14, 2013, 11:52:35 AM »
What do you mean by stopped making power ? Generally such a statement would lead me to say the petcock was failing. But, if you're having a starting issue then maybe it is electrical related. Your statement about the start switch leads me to think you need to clean it. Then I think you need to check the battery and cables/connections as well as the alternator output. I think you're having more than just one problem.
Pete
« Reply #3 on: July 14, 2013, 12:05:24 PM »
Low battery voltage and amperage can cause any bike to die at idle.
Very low voltage and amperage can cause a bike to stop running going down the highway.
So first things first test the voltage at the battery and have a load test done on the battery.
« Reply #4 on: July 14, 2013, 12:09:27 PM »
You sat the battery is good. How do you know this?
Rio Wil
« Reply #5 on: July 14, 2013, 12:27:53 PM »
Sounds to me that your alternator had died, the battery is pretty much rundown to the point it wont run  the electronics module. Try jump starting it and measure battery voltage at say 2000 rpm...should be 13.5-14.5v.......d
« Reply #6 on: July 14, 2013, 12:46:46 PM »
Trying to analyze this kind of problem without the proper tools is more than frustrating.
At the very least, you need a volt/ohm meter.
Art708
Jacksonville, FL
« Reply #7 on: July 16, 2013, 05:20:20 AM »
 If you are running the stock petcock, check the vacuum line to it.  Mine came off one time and the bike wouldn't crank.
Art
 2014 Kawasaki Concours 14
  Black
« Reply #8 on: July 16, 2013, 06:55:01 AM »
Question Art708.  What has a vacuum line got to do with it not cranking?    I'm assuming you are referring to the engine turning over.
Bradb
Benton ky
« Reply #9 on: July 16, 2013, 12:05:01 PM »
Check your bank angel sensor. It bolts to the backside of the cover that has the lock in it to remove seat.  FYI the rounded part should be facing down towards the ground. Ball inside may be stuck.
Art708
Jacksonville, FL
« Reply #10 on: July 17, 2013, 06:18:05 AM »
  Cranking to me, means starting and running. I could be wrrrrrroo mistaken and cranking means just turning over via the starter. But I guess I didn't pay attention to what the OP said. That's what I get for just skimming over the post......sorry y'all.
Art
  Black
« Reply #11 on: July 17, 2013, 07:51:22 AM »
Most people and all mechanics would say cranking is turning the motor using external means, such as a starter motor, for the purpose of starting it.
« Reply #12 on: July 17, 2013, 11:07:10 AM »
Here....just to keep the thread on track.
No blown fuses.
Good battery.
Idea's ?
           thanks,
                      John
Rio Wil
« Reply #13 on: July 17, 2013, 07:24:12 PM »
Soooooo.....what happened to JJ1?
saddlesore
« Reply #14 on: July 17, 2013, 07:46:03 PM »
Could be he works 2nd shift.  He posted after 1.00 AM Smiley
GotValk
Champlin, MN
« Reply #15 on: July 18, 2013, 07:33:23 PM »
When my bike did that it was the alternator, same problem you described.
JamminJohn1
Tug Hill
« Reply #16 on: July 22, 2013, 12:14:24 PM »
Hi guys.
Thanks for the replies/ideas !  Wink
The battery terminals were corroded and could have been tighter.
I cleaned them up & put the charger on.
It stayed on charge mode for longer than I'm used to but eventually came up.
I got the multimeter out and it was 12.7 volts for just the battery.
I cranked the motor (it spins fast & starts right up) to 3k rpm's & got 14.2 volts.
I rode the bike with trailer last night and it got me home.
I hope it's fixed.
Thanks again for the replies.
                              JJ
MarcusS
New To Me August 2013
North Houston
« Reply #17 on: July 22, 2013, 07:31:06 PM »
I just learned something new. The battery terminals should be checked at least once a year. They can loosen up if not properly torqued.  No juice and it dies.
Life goes on whether you are in it for the ride or not.
Karen
Boston MA
« Reply #18 on: July 23, 2013, 02:56:09 PM »
When they really loosen up, they spark & eat up the battery terminal a little bit at a time until there's nothing to put the clamp around. Don't ask how I know this...
JamminJohn1
Tug Hill
« Reply #19 on: July 27, 2013, 08:45:30 AM »
Oh well.That wasn't it.
She quits runnin' when she warms up.
If I press the starter the lights dim like always.
If I short out the starter solenoid she spins but no spark !
Seems like power to the electronics cuts out.
The bike runs great when it runs.
Is it likely that the wiring harness plugs are corroded ?
Less likely that there is a broken wire somewhere ?
Bad ground somewhere ?
Thanks for lookin' & helping.
               JJ
« Reply #20 on: July 27, 2013, 08:54:51 AM »
Find this guy under the right side cover and see if it looks like this, if so, ya need to replace the melted connections.
With this part # from Honda.
Move the big red wire to the empty slot then splice solder and heat shrink every thing.
Farther
Quimper Peninsula, WA
« Reply #21 on: July 27, 2013, 08:57:03 AM »
I am not mechanic but you may have two problems.  A poor battery and an intermittent ground.
~Farther
JamminJohn1
Tug Hill
« Reply #22 on: July 27, 2013, 09:06:02 AM »
I borrowed a known new battery.
The ground somewhere or wiring harness plugs may be the culprits.
thanks,
           JJ
« Reply #23 on: July 27, 2013, 09:16:16 AM »
Spend a little money
JamminJohn1
Tug Hill
« Reply #24 on: July 27, 2013, 09:29:31 AM »
I will peek at it BUT I changed the solonoid about a month ago & didn't notice anything like that.
                                      JJ
JamminJohn1
Tug Hill
« Reply #25 on: July 27, 2013, 09:30:58 AM »
I have one.
               JJ
« Reply #26 on: July 28, 2013, 05:42:27 PM »
See reply #16 Ricky.  "Multimeter" usually means volt/ohm meter.  Now try and go back to trying to helping this guy and read carefully what he has done.
Hay Cool
Rio Wil
« Reply #27 on: July 28, 2013, 07:10:41 PM »
When you are cranking the engine (and it is not starting) , what is the battery voltage then?
« Reply #28 on: July 29, 2013, 07:26:44 AM »
Hay Cool
And your only contribution to this thread is to come on and post a criticism of me.
Slink away creep.
Farther
« Reply #29 on: July 29, 2013, 01:52:33 PM »
Slink away creep.
I agree with HayHauler on this one!!
~Farther
Rio Wil
« Reply #30 on: July 29, 2013, 02:21:10 PM »
Slink away creep.
I agree with Ricky-D on this one....its OK to bash a guys post, but there is a prerequisite that you must make a contribution to the diagnosis effort first 2funny 2funny 2funny 2funny 2funny
Plus JJ1 had already responded to R-D that he had one......so the HH post was redundant....
Kinda like buying a fishing license......before ya fish.... crazy2
And I have no idea why I am even getting mixed up in this..... crazy2 crazy2 2funny 2funny 2funny
JamminJohn1
Tug Hill
« Reply #31 on: July 29, 2013, 06:41:56 PM »
Haven't measured the voltage whilst spinning the no spark motor yet. Wink
I broke the terminal on the perfectly good battery.  Cry
I have to connect it somehow.
Thanks for the helpful replies. Grin
I dismantled the bike some more by removing the sidecovers,front cover,antifreeze tank,& all the fasteners for the battery box.
                JJ
olddog1946
Moses Lake, Wa
« Reply #32 on: August 03, 2013, 04:25:58 PM »
This may or may not be your problem but yesterday I rode my bike up to a local auto repair shop to use their commercial air compressor to remove the frozen pistons in one of my spare calipers..Got six blocks from sis's house and the bike quit..just started spittin and sputtering.. got off on a side street, pulled a plug checked for spark, had it, bike would crank fine but not run at all..smelled the plug.............NO FUEL.... I had replaced the petcock with a new one not 20 miles after leaving LaCrosse headed to my sis's, vent hose was not plugged, glass fuel filter had almost no fuel in it. Had to lift the tank to find a kink in the fuel line (once warm the hose softened up and kinked).  Got that squared away, got my fuel back to the carbs and back on the road. I now have some extra fuel line in my goody bag.
So, I you get your new battery and still won't start, make sure you're gettin fuel.
« Last Edit: August 19, 2013, 07:36:13 AM by olddog1946 » Logged
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
JamminJohn1
Tug Hill
« Reply #33 on: August 04, 2013, 12:26:54 PM »
No sputtering.
The engine stops running electricly.
Power is gone right away.
It's an open connection to the ECU.
                              JJ
Bagger John - #3785
« Reply #34 on: August 05, 2013, 06:27:44 PM »
No sputtering.
                              JJ
If so, what's the commonality? My SWAG would be the crank triggers...possibly the connector block that ties them into the rest of the harness. After that, look at the voltage feed to the ECU.
This bike only exhibits the symptoms when warmed up, correct?
JamminJohn1
Tug Hill
« Reply #35 on: August 28, 2013, 06:04:38 PM »
Yes.
Everything stops working but the lights.
She's been a great bike.
               JJ
