November 25, 2025, 09:08:31 PM *
Author Topic: OVERSIZE FRONT TIRE  (Read 862 times)
cajundood
Down in da Swamps of Louisiana
« on: July 17, 2013, 08:11:57 AM »
Hi all. I'm getting near that point where I have to start thinking about replacing the front tire. I am running a 130 90 17 double darkside. My question is: what is the largest tire that will fit under the fender? I want to go as large as i can. I have had so many different front tires, I don't even remember what is stock.. ???
LIFE's BETTER ON THE DARKSIDE
« Reply #1 on: July 17, 2013, 10:59:23 AM »
Stock is 150/70-17
You'll not be able to find a larger tire (available) that will fit under the fender.
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #2 on: July 17, 2013, 06:29:56 PM »
    HOW MANY MILES HAVE YOU GOTTEN OUT OF THE 130-90-17 FRONT RUNNING BACKWARDS?
« Reply #3 on: July 17, 2013, 06:59:20 PM »
Stock is 150/70-17
Typo?  Stock is 150/80/17 and for some reason the E3 is wider than other 150/80 tires.  The E3 tire is the fattest tire you will get in that fender without a modification
« Last Edit: July 17, 2013, 07:20:19 PM by Chrisj CMA » Logged
