November 25, 2025, 09:20:51 PM *
Author Topic: mityvac  (Read 1083 times)
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« on: July 22, 2013, 10:36:59 AM »
just a little input Please:
was reading some posts and the Mityvac is mentioned so I looked them up and there are close to a Zillion choices to choose from can someone enlighten me as to which kind I need for such things as pulling a vacuum  to fill the bowls,  also I have a 1 man brake bleeder (non vacuum) so it could be used for that also as well as anything else that comes up.  looks like the Silverline Elite Plus is the do everything pump but do I need this?  would like to hear from those who know.
thanks,
Wewa
If you please God it doesn't matter who you displease   but if you displease God it doesn't matter who you please Smiley
chrise2469
Winnipeg Manitoba Canada
« Reply #1 on: July 22, 2013, 11:23:38 AM »
The Silverline elite MV8500 is a pretty fancy metal with pressure and vacuum gauge.
I've got the  MV8010, that's the plastic body with a gauge.  It doesn't measure pressure.  I'd recommend this one so you can have a visible check for vacuum leakdown ( on the petcock). The mityvac makes all your brake and clutch bleeding a piece of cake
If your going to use the pressure side for other applications you may consider the MV8500 but the cheaper MV8010 does everything I need at half the price of the MV8500.
Hope this helps you out.
Ride safe.
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #2 on: July 22, 2013, 02:22:35 PM »
ok thanks that sounds good to me cooldude
« Reply #3 on: July 22, 2013, 05:57:11 PM »
Some other choices.
http://www.harborfreight.com/catalogsearch/result?q=Vacuum+pump
My rides:
MarcusS
New To Me August 2013
North Houston
« Reply #4 on: July 22, 2013, 07:12:54 PM »
I bought the mityvac from harbor freight 39522 and it works great for bleeding the brakes and clutch. Really sucks the #&## out of it. My fluids were so BAAAD that I had to scrape the grit out of my clutch reservoir.  I used it to test my petcock to.
Life goes on whether you are in it for the ride or not.
