February 07, 2026, 01:14:54 PM
Front forks --- Interchange ?
Topic: Front forks --- Interchange ? (Read 1122 times)
gregk
Retired
Chippewa Falls, wi.
July 22, 2013, 08:15:30 PM »
Is their any front forks that interchange with the I/S still in existance, cause If i keep this bike I'm going to need 2 forks complete.
Westsider
Fort Worth TX.
Re: Front forks --- Interchange ?
July 23, 2013, 03:31:41 PM »
The VTX 1800 look identical,from work parking lot, but don't know for a fact. I would like to know.
If they do, it would open up lots of front wheel options.....
Last Edit: July 23, 2013, 03:34:35 PM by Westsider
we'll be there when we get there - Valkless,, on lookout....
BonS
Blue Springs, MO
July 23, 2013, 03:33:06 PM »
Greg, check you PM.
Westsider
Fort Worth TX.
July 24, 2013, 04:37:20 AM »
Find any??? ??? ???
July 24, 2013, 06:56:36 AM »
The VTX 1800 forks are able to be mounted on a Valk, but then mounting the wheel would be a problem. The VTX uses a digital speedo sender. I don't know about the width between the forks. Fender mount bolts are different. VTX forks are about 3/4" longer.
Westsider
Fort Worth TX.
July 24, 2013, 08:58:02 AM »
Do they fit in the valk triple tree's or do you have to have the vtx tree's? Thanks ,,
Good info for rescue / rebuild
Last Edit: July 24, 2013, 09:02:44 AM by Westsider
Reply #6 on:
July 24, 2013, 01:58:16 PM »
VTX forks are the same diameter so they should fit.
