February 07, 2026, 07:47:24 AM
Lower fork replacement
Topic: Lower fork replacement (Read 927 times)
xharleyman
July 23, 2013, 06:38:08 PM »
Hello, I'm new here and have a question. I bought a 2000 valk standard and the lower forks are bent, I got the right fork apart no problem. On the left side do i need to take that nut off that holds in the dampening rod to remove the lower fork? Thanks in advance
tank_post142
south florida
Re: Lower fork replacement
July 23, 2013, 10:06:54 PM »
sent you a message
I got a rock
VRCCDS0246
July 24, 2013, 02:01:02 PM »
Tank probably covered this, but the left fork has no lower bolt. Only the right fork has a dampener inside. If you want to remove the top bolt, loosen the top pinch bolt while keeping the lower pinch bolts tight. Use a 15/16" box wrench to loosen it, then remove from the trees.
