February 07, 2026, 07:47:28 AM *
Author Topic: Got a shiny desmog kit...  (Read 1925 times)
biguglyman
Brockport, NY
« on: July 24, 2013, 05:36:39 PM »
...looking for walk-through with pix or video if available. Tried to search and found a couple desmog articles but nothing specific to the redeye shiny version.
Daddie O
Elk Grove, CA
« Reply #1 on: July 25, 2013, 12:05:36 AM »
The kit comes with good instructions.  Here is a pic of everything we removed.  Mine is a California model so there are a few more pieces we had to remove than yours if yours isn't a California model.
Light moves faster than sound.  That's why some people appear bright until you hear them speak.
quexpress
Montreal, Québec, Canada
« Reply #2 on: July 26, 2013, 06:04:38 AM »
Not specific to the kit that you have purchased .... but the steps are all there.
http://www.valkyrieriders.com/shoptalk/desmog.htm
 Smiley
I still have a full deck.
I just shuffle slower ...
biguglyman
Brockport, NY
« Reply #3 on: July 26, 2013, 11:33:53 AM »
Thanks, that will do. Those pix will come in handy. Just afraid I'll bite off more than I can chew. Funny, I had to completely tear apart and rebuild my computer 5 times yesterday chasing down what turned out to be two separate problems. I got no problem with that. Doing the same thing to the Valk makes me nervous. Oh, and just so you know, I hate Montreal. If you're a soccer fan, you know why. I live near Rochester, NY. Evil
Chiefy
Sarasota, Florida
« Reply #4 on: July 26, 2013, 04:38:38 PM »
Read the instructions a few times before you start.  It's not bad.  Also, don't forget to plug any openings with rags before you start sawing on a tube.
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #5 on: July 26, 2013, 05:27:11 PM »
I had just completed the Shiny Desmog about 2 weeks before Inzane,  take your time and all will work out perfectly.
If you have any questions feel free to PM
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
« Reply #6 on: July 26, 2013, 05:40:46 PM »
Don't forget to plug the air filter opening where the PAIR valve system was connected. If you remove your intake tubes, probably should replace those O-rings. If you pull the tank and the air cleaner, let us know so we can give you advise on how to get those carb tubes back in place properly. It's not a bad job, as has been said just don't be in a hurry.
My rides:
cantom
Ontario
« Reply #7 on: July 28, 2013, 04:20:27 PM »
Is there any real reason to remove the tubes? One could save a lot of bs by just removing the Pair valves and plugging the tubes into the air filter box with this kit couldn't one?
http://redeye.ecrater.com/p/14863425/desmog-refit-kit-honda-valkyrie
Also, does desmogging change the required carb jetting?
Chiefy
Sarasota, Florida
« Reply #8 on: July 28, 2013, 08:05:26 PM »
No reason why the kit you listed won't work.  Some think the engine area looks nicer without the tubes.
No rejetting required.
« Reply #9 on: July 29, 2013, 04:00:50 AM »
+1 on what Chiefy says. Once you get it all back together it should run as it did before. I resynchronized my carbs too just for a finishing touch after the desmog.  Roll Eyes
My rides:
