If you turn the key to the right (I believe), it will unlock the trunk with the key. If you turn the key to the left (I believe), and take the key out...you can unlock with the lever under the trunk. (If I am wrong on my directions, reverse and try again.)
Joe
Go figure...I got it backwards...
Leave the key to the right to be able to unlock the trunk from the lever under the trunk.
