February 07, 2026, 07:47:30 AM
Mobil 1 15/50 vs. 10/40
Topic: Mobil 1 15/50 vs. 10/40 (Read 1783 times)
Bocephus
97 Valkyrie
Elizabethton, TN.
July 27, 2013, 07:32:38 PM »
Why use 15w50 and not 10w40. The manual calls for 10W40 so why are people using the 15W50 mobil 1 instead. Are there any benefits to this. ???
Farther
Quimper Peninsula, WA
Re: Mobil 1 15/50 vs. 10/40
July 27, 2013, 09:33:43 PM »
This is my understanding:
The Mobil 1, 10w40 is a motorcycle specific oil and good for a wet clutch. The 15w50 is a diesel engine oil and also compatible with a wet clutch. The auto version of the Mobil 1, 10w40 is not compatible with a wet clutch. The diesel engine oil is significantly cheaper than the motorcycle specific oil.
~Farther
July 28, 2013, 04:25:14 AM »
I have use the automotive 10/40 many times, no problems. Also use the the 15/50. It's all in which one is on sale. Neither one has the additives harmful to a clutch. Hoser
Bocephus
97 Valkyrie
Elizabethton, TN.
July 28, 2013, 04:44:53 AM »
Thanks guys for the info. If you go to Mobil's website you can print $10.00 coupons for any Mobil 1 oil at autozone. Every little bit helps.
Bocephus
97 Valkyrie
Elizabethton, TN.
July 28, 2013, 04:47:48 AM »
http://www.mobiloil.com/USA-English/MotorOil/Promotions/Promotions.aspx
Here is the link for the coupons.
JaysGone
Delray Beach Florida
July 28, 2013, 04:49:41 AM »
50 weight oils for the most part also quiet down most engine noises a bit more..
I use 20w-50 in all my bikes and the trike here in Florida.
90 degree days and 35 miles an hour my fans are on a lot.
1999 Valk - SOLD
2005 Yamaha RoadStar
Reply #6 on:
July 28, 2013, 07:06:34 AM »
Quote from: Bocephus on July 28, 2013, 04:47:48 AM
Thanks for the tip, Bochepus, printed one.
miscott
Keep the rubber side down and hang on tight!
So. Central Kansas
Reply #7 on:
July 29, 2013, 07:01:37 AM »
+1
