February 07, 2026, 09:47:14 AM
trailer wiring
Topic: trailer wiring (Read 1245 times)
trailer wiring
July 28, 2013, 08:01:51 PM »
Last year I bought a trailer, wired everything up but did not use a power converter. The lights are really dim during the day. Im wondering if I convert all the lights to led is a converter still needed considering they draw a lot less than incandescent bulbs?
Re: trailer wiring
July 28, 2013, 08:14:53 PM »
If you convert to LEDs, you don't have to use the powered converter. I have the Hoppes #46255 powered unit on both bikes. I use conventional bulbs and have very bright lights.
Re: trailer wiring
July 28, 2013, 08:22:04 PM »
I was wanting to go with led's anyway. I dont know my reasoning for not adding a converter last year, I bought one and now it is missing. Ill just order some led replacements and go that way. Thanks for the reply sandy
Re: trailer wiring
July 29, 2013, 10:32:26 PM »
If your trailer lights have separate yellow turn signals like your bike, it should work, except for overloading your light circuits. LEDs as trailer lights would be better than incandescents because of the lower current draw. If your trailer has combined brake/signal lights like most trailers do, you'll need a converter. Some converters take power for he trailer lights directly from the battery to prevent overloading the tow vehicle's wiring.
Re: trailer wiring
July 30, 2013, 02:25:45 PM »
It has 2 6 inch oval red brake lights and 4 amber 2 inch round signal lights. So yes they are seperate.
Re: trailer wiring
July 30, 2013, 09:01:01 PM »
Quote from: Gavin_Sons on July 30, 2013, 02:25:45 PM
Separate is the easiest to wire up.
Hay
Re: trailer wiring
Reply #6 on:
August 01, 2013, 06:32:24 PM »
So I got all the replacement led lights for my trailer and ther are 100 times brighter. Very happy with the upgrade. Ill road test it saturday when I load it with my new tires and go to rainmans to change tires.
