February 07, 2026, 07:46:44 AM *
Author Topic: bike shuddering  (Read 1553 times)
elpaso jo
Meath Co. Ireland
« on: July 29, 2013, 10:25:07 AM »
Guys,
any advice on this,I took my valk out for a ride last week for about a 30 mile spin. All went well, as I parked it up to open garage door, stepped back up on her, selected first gear, began to move forward i noticed a kind of vibration or a shudder as i moved forward, this happened as I released the clutch.
I then took it back on the road and it disappeared, however, as i stopped and moved away it happened again
Have I a clutch problem ?
« Reply #1 on: July 29, 2013, 10:31:33 AM »
Sounds like a good possibility, check the level of the fluid in the clutch handle reservoir first. If it is dark colored it needs flushed and refilled with new fluid.  Hoser
elpaso jo
Meath Co. Ireland
« Reply #2 on: July 29, 2013, 10:58:39 AM »
Thanks hoser, Im terrified I will get a reply that tells me my clutch is f ***ed.I will check your suggestion.
Thank you
Marinakorp
King of Prussia, PA
« Reply #3 on: July 29, 2013, 11:07:15 AM »
Your Clutch is F****d
Sorry, couldn't resist.
Check the color and level
I would rather be judged by 12 than carried by 6
elpaso jo
Meath Co. Ireland
« Reply #4 on: July 29, 2013, 11:34:28 AM »
I know your right, I walked into that one !!. Wont see anything on the bike till weekend so reservoir and colour will be checked then.
If anyone has anymore tips, love to her them (no bad news pppplease)
Thanks Guys
« Reply #5 on: July 29, 2013, 12:14:23 PM »
With the little bit of information you supply I would have to say that that sounds to me like operator error or the wrong oil in the motor.
elpaso jo
Meath Co. Ireland
« Reply #6 on: July 29, 2013, 01:39:04 PM »
Well Im explaining it best i can, it never happened before.
Thank ye all for replys and if is any help to you boys or any other biker when I get it sorted I will post the results.
Ye are d best
Ta
Farther
Quimper Peninsula, WA
« Reply #7 on: July 29, 2013, 01:46:00 PM »
Your words are how I discribed what my bike does too on occasion.  I have the correct oil and good fluid.  It has done it for about three years off and on for about 10k miles.  It has not progressed to anything else.  I am just going to ride it until something happens and then fix it.
Just ignore Ricky-D, he might be one of your British countrymen hiding out in the USA.   Roll Eyes
~Farther
elpaso jo
Meath Co. Ireland
« Reply #8 on: July 29, 2013, 02:13:12 PM »
Thanks Farther, thats good news anyway, but just to clarify something Im Irish with a bit of Southern Confederacy in my blood he he !
« Reply #9 on: July 29, 2013, 02:36:36 PM »
How many miles on this monster ? How has it been ridden ? Any clutch shudder when taking off in first is generally a sign of sheared rivets. May be time for a little clutch repair.
elpaso jo
Meath Co. Ireland
« Reply #10 on: July 29, 2013, 03:06:19 PM »
Howdy Patrick,
There is 32678 on the clock, I had some problems at one stage with getting neutral, that seemed to go away after some adjusting and checking for air in the system.
i do believe that there is still something unusual going on still as my brothers Valk is smooth while changing gears in fact there is no comparison with his and mine
I am concerned that there is a problem. I admit that Im in no way mechanically minded.
I thought these bikes were bullet proof ----maybe they are and Im a wimp !!
Valkpilot
What does the data say?
Corinth, Texas
« Reply #11 on: July 29, 2013, 06:04:17 PM »
Howdy Patrick,
It's rare to actually wear out a Valk clutch.  Most times, clutch problems go away when you completely replace the fluid and bleed the system properly.
But, along with that, check the condition of the lever, the pivot bushing in the lever, and the bushing for the rod that pushes into the master cylinder.
The rivets in the damper plate of the clutch pack do come apart sometimes.  It has mostly been known to happen in 97 and 98 models around 60,000 miles.  The true telltale sign of this is when the clutch handle won't pull all the way to the grip.  This may be an intermittent symptom.
Replacing the clutch isn't that hard a job: http://www.valkyrieforum.com/bbs/index.php/topic,20870.0.html
« Last Edit: July 29, 2013, 06:07:20 PM by Valkpilot » Logged
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
saddlesore
« Reply #12 on: July 29, 2013, 06:56:13 PM »
Something else I thought of was that since you have a wet clutch the wrong motor oil or oil that should be changed may cause a problem.
I run a synthetic oil and though they say I can run it for 8000 miles I've noticed that around 6500 miles things just don't seem right.
Just a thought.
 Smiley
DARE TO BE DIFFERENT
Joevalk
Santa Fe, Texas
« Reply #13 on: July 29, 2013, 07:54:31 PM »
Mine was doing a lil shudder too. I notice pivot bolt for the clutch lever needed a lil lube. Also the brass piece might have some wear. I flushed the whole system, I even pulled the slave cylinder and cleaned out all the mud that built up over the 113k miles.
VRCC#32720
1999 Grn/Silver Interstate
