February 07, 2026, 07:46:33 AM
turn signal indicator
Topic: turn signal indicator (Read 1109 times)
quirkyguy001
finally found a way to hold the dragon back
Tulsa, Ok
July 30, 2013, 02:30:29 PM »
Help, I need to change the turn signal indicator on the headlight bucket of my 1998 standard valk. Does it pry off or what. Don't want to risk damaging the top of bucket
Used to buy new bike every two years. Can't find anything to upgrade to. Harley rider for 40 years. Nough said
Former BMW Guy
Aut viam inveniam aut faciam.
Apple Valley, MN
Re: turn signal indicator
July 30, 2013, 02:59:07 PM »
I think you need to get at it from inside.
JP
Motorcycling is not, of itself, inherently dangerous.
It is however, extremely unforgiving of: inattention, ignorance, incompetence or stupidity.
justintyper
syracuse,ny
July 30, 2013, 03:04:49 PM »
http://www.valkyrienorway.com/download.html
on this page you'll find the factory repair manual
quirkyguy001
Tulsa, Ok
July 30, 2013, 03:20:05 PM »
Thank you, but manual doesn't show how to disassemble
Moonshot_1
July 30, 2013, 03:59:09 PM »
I recently had to change the high beam indicator light. It is the same light set as the turn signal.
You have to get to it from the inside. There is a rubber boot that traverses the headlight. The bulb is nestled deep inside the boot. I had to use a tweezers to get it out. I'm sure there is a proper tool for that. I don't have one.
The amber lens (in my case, the blue one) simply sits in the boot.
I would suggest gently prying the lens cover off of the headlight then pulling the boot out from the inside of the headlight.
When I did this, I just pulled on the boot from the inside and the lens went flying.
Don't let the lens go flying. Gently remove it first. Take the old bulb to the local auto shop. It must be a common bulb as NAPA has them.
I used a small socket on a "screw driver" to insert the bulb, as it is a rather deep boot. Took a number of attempts. Again, I'm sure there is a proper tool for this. I don't have one.
(The bulbs just pull out and push in)
I cannot guarantee this is the proper way. But it worked for me. And I too, could not find any information on how to do this.
Mike Luken
Cherokee, Ia.
Joevalk
Santa Fe, Texas
July 30, 2013, 04:02:55 PM »
You have to pry the plastic indicator lens out first then you can pull the rest out from the inside. A lil shot of wd-40 helps.
VRCC#32720
1999 Grn/Silver Interstate
quirkyguy001
Tulsa, Ok
Reply #6 on:
July 30, 2013, 04:05:03 PM »
thank you. got what I needed
