February 07, 2026, 11:32:25 AM *
Author Topic: headlight change  (Read 1262 times)
dubsider
Flat6 baby #33034
Dublin GA
« on: August 03, 2013, 06:31:19 AM »
I have a new headlight BULB I want to install.. is there a trick to remove the small reflector shield that goes over the bulb so I can install the new bulb??
« Last Edit: August 03, 2013, 07:31:19 AM by dubsider » Logged
« Reply #1 on: August 03, 2013, 07:36:10 AM »
I believe the "shop talk" pages cover headlight removal and reinstall. If not there the Honda service or Clymer service manual cavers it. RIDE SAFE.
dubsider
Flat6 baby #33034
Dublin GA
« Reply #2 on: August 03, 2013, 07:40:13 AM »
shoptalk does not seem to cover the small reflector dodad..
« Reply #3 on: August 03, 2013, 08:15:52 AM »
Most all headlight bulbs are installed at the back side of the assembly.
If you're thinking to install it at the front, that's probably the wrong way.
« Reply #4 on: August 03, 2013, 08:17:38 AM »
Standard/Tourer or IS?
If its  a stnd, you just remove the bezel remove and replace bulbs and youre done, no messing with that shield thing
dubsider
Flat6 baby #33034
Dublin GA
« Reply #5 on: August 03, 2013, 08:24:57 AM »
got it thanks... from the backside  coolsmiley
F6Dave
« Reply #6 on: August 03, 2013, 10:20:21 AM »
Just a reminder to not touch the bulb when installing.  The oil on your fingers creates a hot spot and can ruin the bulb quickly.  If you slip and touch it just wipe it off with some rubbing alcohol.
