November 25, 2025, 09:27:46 PM *
Author Topic: Opinions on charging system  (Read 1338 times)
« on: August 05, 2013, 10:10:59 AM »
I have 120,000 miles on my original alternator, four year old battery.  Check up is as follows:
Ignition off, been in garage for a week. 12.62 volts on battery reading.
Engine running at 1000 rpm, driving lights off. 14.2 volts.
Engine running at 2000 rpm, driving lights on. 14.1 volts.
Does anyone think I need to do anything other than carry my spare alternator when I take a trip?  I usually just put it in my saddle bag.  I'm going to Arkansas for a few days in September.  Hoser  Smiley
PatrickDoss
Alabama
« Reply #1 on: August 05, 2013, 10:23:47 AM »
Most would say to go ahead and check (replace) the brushes in the original alternator with that mileage. Whether you do or not, I'd still take the spare on the trip Wink
Pete
« Reply #2 on: August 05, 2013, 10:27:28 AM »
Perform a load test on the battery.
Other than that not sure there is anything else to do other than ride.
Good luck and have fun.
« Reply #3 on: August 05, 2013, 12:06:40 PM »
12.62 v is not a sign of a fully charged battery,
I would say that is the place to watch.
« Reply #4 on: August 05, 2013, 03:14:51 PM »
If you have a spare alternator then why not just toss in the bag. Or if you're that concerned why not stick in a set of brushes and bearings in the one you're using/running.
« Reply #5 on: August 05, 2013, 03:46:27 PM »
Ithink I'll carry the new one and change it out if I need to. That seems to be the best way to go. Plus, if I'm with someone who has problems I can fix him up.   I'd have to pull it anyway to replace the brushes.  I will get the old one rebuilt if I have to change it out.  Ain't no big thing to change it out.  Hoser  Wink
« Reply #6 on: August 05, 2013, 05:22:26 PM »
If the battery has those readings and is four years old, I'd say it's time to replace it before Murphy's Law goes into effect. Essentially, that old battery will die on you at the most inopportune time....usually middle of the night and middle of nowhere, with no cell phone service. Been there, done that....just once many years ago, causing me to replace my battery about every three years whether it appears to be needed or not.
« Reply #7 on: August 05, 2013, 06:53:22 PM »
Change the brushes if you havent already.  And, get a new battery...put a full charge on it before using it
« Reply #8 on: August 05, 2013, 07:10:36 PM »
Not something I'd like to do on the side of the road its a bitch doing it in a well lit garage . I seem to be riding more and more at night maybe its the cool night air maybe I just dig screamin' down the road in the dark  Undecided  I'm not so sure I could change the alternator on the side of the road  Undecided
« Reply #9 on: August 06, 2013, 06:32:46 AM »
I've done it before, not by the side of the road though!  Shocked Hoser
