April 28, 2026, 10:46:43 PM *
Author Topic: Ready to adjust steering bearings  (Read 2230 times)
houstone
Can't get enough...
Santa Fe, TX
« on: November 05, 2008, 08:18:38 PM »
Anyone got  some pointers?  I have a manual, new lock washer and Honda socket tool is on the way.
Thanks!
Jeff
ps  I love my Valk!  ;-)
cutter
Plantersville, Texas
« Reply #1 on: November 06, 2008, 06:30:44 AM »
Are you sure you don't need to replace the bearings? I replaced mine about a year ago. I didn't have the honda tool and managed OK. I did snugged it up a while back. I have an I/S and all I did was to pull the bars and removed the top of the tree and snugged it up. The reason I did it was because it was begining to fall to easy to the side. No problems since.
Rocketman
Seabrook, Texas
« Reply #2 on: November 06, 2008, 08:20:24 AM »
Jeff:
Glad to see you made it over here.
You could get some pointers in person on Saturday, if you didn't regard your kids as more important than your Valkyrie.  I thought you said you love it!
I've never done that job, so I can't actually help, I can just throw in comments from the peanut gallery every once in a while.  Sorry.
I'm sure some folks here can help out.  I think Cutter's suggestion to just replace them sounds good, though.  Reportedly a bearing failure can be rather difficult to detect, and since you're working on them anyway...
Mark
houstone
Can't get enough...
Santa Fe, TX
« Reply #3 on: March 27, 2009, 02:19:21 AM »
I took the bearings out, cleaned, repacked and torqued 'em up.  It has been fine, but lately I have noticed a "click" again.  Wasn't too bad, but I wish I had just replaced them.  If anyone wants to borrow the tool, in the Houston area, just let me know.
Jeff
Daniel Meyer
Moderator
The State of confusion.
« Reply #4 on: March 27, 2009, 05:07:16 AM »
If they are indexed, they will cause the valk to "hunt", no matter how carefully you adjust them.
Pointers for adjustment are to get the tool (doesn't have to be the honda tool, there's a guy on the 'wing board that makes a beautiful one), and follow the manual exactly. The Valkyrie is extremely picky about this adjustment. Too loose and she will shimmy, to tight or indexed and she will hunt and feel unstable on wet pavement.
CUAgain,
Daniel Meyer
SideCar
Bikers don't need shrinks!
Colleyville, TX
« Reply #5 on: March 27, 2009, 11:27:44 AM »
And, a good fish scale works for measuring pull if you don't have something fancier.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #6 on: March 27, 2009, 12:05:19 PM »
Daniel, (or others) what is the tool? I know I need to replace my bearings (I have new ones) but am very nervous about doing this. I have new fork seals too. I have a leaking one and figured to do both bearings and seals at the same time. I have the fork tool.
I am such a mechanical technotard about stuff like this.
BTW-Hope to see you next weekend at GOTF. (With my leaking seal and indexed bearings ;-)
