November 25, 2025, 09:30:26 PM *
Author Topic: Anyone regret de-smogging their valk?  (Read 4582 times)
trouthunterjohn
Olympia, WA
« on: August 09, 2013, 11:07:38 AM »
I have a virgin 98 std, runs great.
The more I research the de-smog, the more I'm thinking of doing it, before my bike begins to suffer from pair valve and vacuum hose issues.
So, I've heard from the de-smog advocates; but I want to hear from anyone who wished they did not de-smog.
Thanks!
« Reply #1 on: August 09, 2013, 11:16:37 AM »
Done right... I can see no downside.
Of course, we could always end up with some (asswipe) G deciding to require all original OE emissions at inspections.  (Which would require an extensive library and inspectors who know what they are doing...highly unlikely)
I have a whole box of parts from two bikes.... I don't know why I keep it.   It's not nostalgic.
Bambam650
Cincinnati, Ohio
« Reply #2 on: August 09, 2013, 11:42:52 AM »
Nope, no regrets at all.  You can fill a small shopping bag with all the desmog parts you don't need.  Glad to get rid of all that unnecessary weight and have a much cleaner engine bay.  My Valk used to gargle and pop alot on decel before I desmogged it.  Now its smooth as silk.
1997 Standard (Black) original owner, bought new in August 1996
« Reply #3 on: August 09, 2013, 12:28:37 PM »
There are still many that have not been touched and there really is nothing wrong with that. Just keep an eye on the vacuum lines and caps. The original lines are certainly due to be replaced if they haven't been.
« Reply #4 on: August 09, 2013, 03:23:41 PM »
I don't regret it.  But I did have one of the "pipe, air feed" fittings blow out of the hole - right rear, under the Kury valence cover - and I thought at first I had developed an exhaust leak with all the noise it made.  I had just cut off the tube and folded it over to close the hole.  Easy fix, I just added a shim between the valence cover and the top of the fitting and that held it in. No other regrets - no maintenance of that system or all the vacuum tubes I removed.
Garland
#618
Hendersonville NC
« Reply #5 on: August 09, 2013, 04:38:29 PM »
I don't necessarily regret it, but if I had a do-over I would have left my bike close to stock. I think the only real thing mother Honda did wrong was the fuel petcock-definitely change that for a Pingle. The rest is pretty good. Take it from someone that spent $22,000 in the first two years of ownership on bike, paint and upgrades.
« Reply #6 on: August 09, 2013, 06:52:07 PM »
I regret it. It works fine, but after I did mine, I helped Stanley Steamer replace his vacuum lines
with the Red Eye kit, that works fine too. I guess "regret" is too strong, there's no downside to
doing it...
-Mike "if it ain't broke, don't fix it..."
Firefighter
Harlingen, Texas
« Reply #7 on: August 09, 2013, 06:58:24 PM »
Did mine a few years ago. Enjoyed getting rid of all that crap that could cause trouble. Also replaced vacuum lines, (piece of mind) and added cruise control, (neatest thing since ice cream). No trouble, no regret. Have fun!!
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #8 on: August 09, 2013, 08:04:19 PM »
NO regrets here either.  Desmog stopped popping on deceleration, nice clean easy to install any of the desmog kits available.
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
Rumpole
Sydney, Australia
« Reply #9 on: August 09, 2013, 08:25:10 PM »
Where can I read more about de-smogging?
Get the keys, pump up the iPod, let's go ...
Oklahoma_Valk
Central OK
« Reply #10 on: August 09, 2013, 09:47:22 PM »
I regret not desmogging my valk SOONER.
Let those who ride decide.
AZdougness
« Reply #11 on: August 09, 2013, 10:58:34 PM »
tech section of the site has a good write up about it.
It cured my popping under decel too, and when it is done it looks clean as hell under the tank. Room for other stuff...
trouthunterjohn
Olympia, WA
« Reply #12 on: August 10, 2013, 07:23:26 AM »
Thanks for the feedback.  I ordered the shiny kit from red eye and will install it soon.
mmurffy03
03 standard
toms river new jersey
« Reply #13 on: August 10, 2013, 09:15:46 AM »
has any body with cobra pipes stopped the popping during deceleration it seemed to not help my bike one bit after the de smog and that included pilot jet adjustment and a re sync of the carbs ? but when I installed my 2 brothers 6 into 2 pipes I had no popping at all and made no other carb adjustments or changes at all runs great now much more quiet also
« Last Edit: August 10, 2013, 09:19:57 AM by mmurffy03 » Logged
bassman
« Reply #14 on: August 10, 2013, 09:41:19 AM »
Here's a great write up.....
http://www.valkyrieriders.com/shoptalk/desmog.htm
Kep
My "Mid-life Crisis "
Indiana
« Reply #15 on: August 10, 2013, 07:48:39 PM »
I have Cobras...did Shiney de-smog ..pilots at 2-3/4 turns out..scarcely any de-cel pop !Runs ohhhh so smoothe !
Jetflyer
Vale, North Carolina
« Reply #16 on: August 10, 2013, 08:07:50 PM »
I just completed the shinny desmog kit and replaced the remaining vacuum plugs and O ring intake gaskets. I suspected an air leak somewhere(god only knows).
The engine now revs up, holds rpm and decelerates as SMOOTH AS SILK! Very noticeable, and worth the money and time. Everything came frome redeye.
http://redeye.ecrater.com/p/8464393/shiny-desmog-kit-chrome-honda
« Last Edit: August 12, 2013, 06:56:33 AM by Jetflyer » Logged
I'm either driving a Valkyrie or an Airbus... it just depends on the day of the week.
Al in Arkansas
Pea Ridge, Arkansas
« Reply #17 on: August 10, 2013, 08:20:05 PM »
Desmogged two years ago when I rebuilt my carbs.  I run Cobra 6x6 & desmog fixed the popping on deceleration.  Started developing some popping again lately, but took care of that by replacing the vacuum caps on each intake.  I use some rubber caps I picked up at my local parts store.  Seems their life is just shy of 2 years.
No regrets.
Bigun
VRCC# 32964
Monroe, Iowa
« Reply #18 on: August 10, 2013, 09:00:02 PM »
Just did a whole bunch of work to mine and need to get the carbs synced I am getting a slight pop on decel but am sure that will clear up soon.
1999 Valkyrie Interstate
john
tyler texas
« Reply #19 on: August 10, 2013, 09:52:39 PM »
                        ???            whats to regret ?
 " desmog stopped popping on deceleration"        cooldude
                   no more hoses to leak and be concerned about ...
        much cleaner under the tank ...     Shocked          its all good         Roll Eyes
vrcc # 19002
« Reply #20 on: August 11, 2013, 04:49:22 AM »
De-smooged all three, no regrets.
I did it so I can replace it if forced by the babysitting government of the state I live in.
All the chrome pipes are still there, just capped.
All the extra parts are sitting on a shelf.
« Reply #21 on: August 11, 2013, 05:57:12 AM »
doing it...
What are the regrets?  And why wouldn't you do it again?
« Reply #22 on: August 11, 2013, 09:33:19 AM »
doing it...
I can't tell that it does anything other than remove some possible vacuum leaks. It doesn't
soup up your bike. Having helped replace the vacuum lines on Stanley Steamer's bike,
I'm sure it can be left stock and be just fine. Some people feel like de-smog is a must do,
I don't...
Tropic traveler
Silver Springs, Florida
« Reply #23 on: August 11, 2013, 04:41:57 PM »
No.  cooldude
'13 F6B red for Kim
whitestroke
San Pedro, Ca.
« Reply #24 on: August 11, 2013, 09:22:43 PM »
Will only have regrets when Ca. decides to smog check bikes , like they did with my diesel truck. tickedoff tickedoff tickedoff
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
2 Kids 25 year break.
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
Anthony
Belgium
« Reply #25 on: August 12, 2013, 04:56:50 AM »
there is no technical reason to fear a de-smog.
my direct sales Belgian model came without that crap originally.
to me that means that mother Honda thinks that it is not necessary, only to comply with local legislations.
Anthony
9Ball
« Reply #26 on: August 12, 2013, 08:03:10 AM »
Yes, I had my bike dyno tuned with a Factory Pro jet kit...new mains, new shimmable needles.  I would say it cured 90+ percent of the decel popping but if I was very heavy handed on the throttle and suddenly backed off completely there would be the pop...too much fuel.
I gained back 7 hp from stock after dyno tuning....it wasn't cheap but it was worth it for me.
Good luck...
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
