November 25, 2025, 09:27:26 PM *
Author Topic: Exhaust Pipe and Muffler Temperature  (Read 2054 times)
indybobm
Franklin, Indiana VRCC # 5258
« on: August 09, 2013, 11:12:01 AM »
Has anyone checked the temperature of their exhaust pipes and mufflers after a ride?
Just curious how hot they actually get, I know they get hot.
Would like to know just as a reference.
So many roads, so little time
VRCC # 5258
« Reply #1 on: August 09, 2013, 11:18:02 AM »
Only by accident.............. owww.  tickedoff
indybobm
« Reply #2 on: August 09, 2013, 11:25:42 AM »
I was thinking in tems of troubleshooting. I.E. one side, or one cylinder hotter than the rest. Could be a useful indicator.
VRCC # 5258
Bugslayer
Lubbock, Texas
« Reply #3 on: August 09, 2013, 03:19:53 PM »
A couple years ago, I used an Infrared Thermometer to check the temp on my TBR 6-into-6 pipes. (single wall pipes.) The hottest temp I found was 540*. That was on the back pipes, just under the flanges.  I'm sure stock (double wall) pipes will be cooler.
« Reply #4 on: August 09, 2013, 03:30:40 PM »
I get to do a plug.
My 5" stacks get like handwarmers.  In fact, I use them for that if I forget the warm gloves and it turns cold.  With an inch of air space (OK, 1/2" on top, 1" to the side) behind the stacks surface before the hot muffler inside, they won't melt anything.  I never measured them though I do have a temp gun.  But you can put your bare hand on them when fully heated, and leave it there.  It's probably warmer near the outlet, never tried it there - but the stacks near your feet, not hot.
indybobm
« Reply #5 on: August 10, 2013, 11:26:41 AM »
I thought that maybe someone who has an infra-red temperature gun could find out what the 'normal' temperatures are. These could be a reference. Then if you had one cylinder or one bank hotter than the other, it could be an indication of something wrong, such as one cylinder lean or the need of a carb sync.
Anybody that has a gun want to read the temps?
VRCC # 5258
six2go #152
Ft. Wayne, IN
« Reply #6 on: August 10, 2013, 03:41:56 PM »
Checked mine a couple of weeks ago with my shin while wearing shorts. All I can say is, it's F---kin' hot.
Pete
« Reply #7 on: August 10, 2013, 06:24:20 PM »
Search for exhaust temp, there was a thread about a year ago where some temps were posted.
Search did not produce the thread, but I know we posted some exhaust temps.
So try some other search words.
« Last Edit: August 10, 2013, 06:30:01 PM by Pete » Logged
john
tyler texas
« Reply #8 on: August 10, 2013, 09:46:09 PM »
 cooldude                "All I can say is, it's F---kin' hot "
         I searched and read 250f average at end of exhaust
         and 800f average at header ...
           lift your pants and touch exhaust with the inside of your calf ...     Shocked     tickedoff      2funny
vrcc # 19002
« Reply #9 on: August 11, 2013, 05:19:51 AM »
exhaust gas mixture has to be correct first before using pipe temps as a tunning aid. EGM has to be the base line. pipe temps can be hot if too lean or too rich.
indybobm
« Reply #10 on: August 11, 2013, 06:19:48 AM »
Thaks for the responses. I am plaig on getting an infra-red gun, right now I have a digital thermeter with a 5" stem. Not the best I know but if you are careful and place it in the same place on each side you can get a representative readng.
I was checking muffler temps just under the passenger foot rest after a ride. One side was 50 degrees hotter than the other side. I put 1 1/2 can of Berryman's B12 and went for aother ride. When I came back and checked the temps again, they were very close to being the same on each side.This leads me to believe (I did not say assume) that the B12 cleared up a slight clog which caused one cylinder to run hotter than the rest (on the right side).
If you have a baseline on temperatures, this could be a troubleshooting tool and an indication of something wrong. Especially when checking individual headerpipes.
« Last Edit: August 11, 2013, 08:11:36 PM by indybobm » Logged
VRCC # 5258
