February 07, 2026, 11:32:18 AM *
Author Topic: Throttle Cable - Size Matters  (Read 955 times)
Chaosandconfusion
Tallahassee, FL
« on: August 15, 2013, 11:23:57 AM »
I am working on my throttle and was wondering if anybody knows the length of the throttle cable on a 1999 I/S.
Also if you have added bar risers (or not) what size cable did you buy, what and where?
David
Ride Long and contemplate
« Reply #1 on: August 15, 2013, 11:55:19 AM »
Can't tell you length without trying to find them. With the TBR triple clamp and LaMont riser's I put on 3" longer cables [ 2" would have worked fine also]. The originals did fit by re-routing them, but, I didn't like it.
DenverDave
Out past Mars ain't no speed limit -Mojo
« Reply #2 on: August 15, 2013, 05:11:39 PM »
Just measured a spare cable in my parts stash.  From the engine end to the middle of the curve on the throttle end is 37.5 inches the entire cable is just over 42 inches long.
Dave
1999 interstate green/silver
Denver, Colorado
VRCC#32819
VRCCDS#0238
Chaosandconfusion
Tallahassee, FL
« Reply #3 on: August 16, 2013, 07:20:23 PM »
Thanks for the measurements.  I will check this out tomorrow and see what I can do.
