February 07, 2026, 11:32:13 AM *
Author Topic: bike dies  (Read 1192 times)
REDTIM
« on: August 15, 2013, 07:17:21 PM »
riding last weekend IS just shut off and then back on a few time like you were turning the key on and off. Speed o meter, tach, headlights, and radio all went off then back on a few times at two different times that day. You guys got any ideas where to look. The bike had always been kept inside. I have cleaned and greased all the connections in the past just to do some preventive measures. I have never had this problem before other than the alternator going out. Then it was evident the battery was going dead on that one. Help me out if you can.
Rio Wil
« Reply #1 on: August 15, 2013, 07:36:30 PM »
These are the same symptoms I had when the alternator was going bad......a winding in the armature was breaking and finally broke apart far enough it died totally.
REDTIM
« Reply #2 on: August 15, 2013, 07:54:21 PM »
last time that happened to me the battery had to die after the alternator went out this is just like the key cutting off and on
« Reply #3 on: August 15, 2013, 09:19:55 PM »
I`ve had it happen a couple times to me also. Don't know what it is.
« Reply #4 on: August 15, 2013, 09:48:27 PM »
Loose/corroded battery cable (at the battery or ground to block/frame) is also suspect and should be checked first.
And see this thread.  http://www.valkyrieforum.com/bbs/index.php/topic,58781.msg0.html#new
« Last Edit: August 15, 2013, 09:55:33 PM by Jess from VA » Logged
Highbinder
Bastian/Tazewell,VA.
« Reply #5 on: August 16, 2013, 04:35:21 PM »
If your instrument panel went out while the bike was still running and came back on, then intermittent dying of the engine, it sounds like a bad diode to me, it's right along side of the fuse panel...it looks like a vertical fuse...the only way I know of how to check it, is to put another one in, local dealer should have them..if its bad it will also kill the engine.
« Reply #6 on: August 17, 2013, 03:28:30 PM »
Clean up the terminals on the main relay under the right side cover.  Mine did that, cleaned it up, never did it again.  Hoser  Wink
PhredValk
Edmonton, Alberta, Canada
« Reply #7 on: August 17, 2013, 04:41:07 PM »
It's either the alternator or a main connection loose or badly corroded. That is what my IS did until the battery finally died in Thunder Bay this summer. Alternator was toast.
Thankfully Gary at M.A.R.S. http://myplace.frontier.com/~hemi-roid/ had two on the shelf ready to go, 'cause that was the July long weekend and Honda was back-ordered on GL class engine alternators till mid August.
Fred.
VRCCDS0237
REDTIM
« Reply #8 on: August 18, 2013, 10:31:23 AM »
Thanks for the advice I just now am getting the time to look at it I will let all of you know what I find.
