Hellcat
« on: July 09, 2009, 11:03:01 PM » |
I read among the "known Valkyrie problems" on the shoptalk page that gas fumes could leak out of the keyhole on the gas cap.
My new-to-me 97 Valk does seem to have this problem. Any fixes for this, or where would I look for a new gas cap?
Unlikely Honda would replace it after twelve years and three owners.
RLD
'99 I/S Red/Black
Eden Prairie, MN
« Reply #1 on: July 10, 2009, 05:07:55 AM » |
They're around $55 new. Thats what I do.
Dress for the slide, not the ride. ATGATT VRCC #2505
Joe Hummer
Arnold, MO
« Reply #2 on: July 10, 2009, 05:19:20 AM » |
I would check two things before changing out your whole cap. First...make sure the tank vent line isn't kinked or plugged. Second...check the gasket around the cap...it is it give out...you might be able to find just the gasket or fashion something that will work. Check out this post for information about making your own gasket: http://www.valkyrieforum.com/bbs/index.php/topic,5132.0.htmlJoe
1999 Valkyrie Interstate You pay for the whole bike, why not use it Jerry Motorman Palladino
Jeff K
« Reply #3 on: July 10, 2009, 06:49:18 AM » |
Here is what I did. The gasket on the cap is donut shaped. Take the gasket off of the cap Make a donut shaped gasket shim out of some 1/32" gasket material Put the shim inside the OEM gasket Put the gasket back on with the new shim inside. This will take some patience. It may be a little stiff to close but it will get better with some time. I did this 6 years ago and it solved the problem.
Hellcat
« Reply #4 on: July 10, 2009, 10:04:38 AM » |
Thanks to all. Good info.
« Reply #5 on: July 10, 2009, 10:15:35 AM » |
I too have noticed the smell of gas comming from the cap.
Not wanting to pay for a new cap or go to the trouble of making a new gasket.
I decided to lube the old gasket with silicone lubricant (I just sprayed some on a rag and then wiped the gasket with a lberal coating).
This seems to be working, the silicone will "restore" the gasket as long as there are no cracks or missing chunks.
I'm thinking that this needs to become something that I do periodically.
It's at least worth a try.
Baloo
« Reply #6 on: July 10, 2009, 12:24:05 PM » |
Seems like a common problem, I too have this one. I like the idea of the silicone lubricant. Think I'm gonna try it. If it doesn't help, I'll use Jeff's solution. How do you take the cap off? I guess there are some screws? Where?
Thanks!
Never ride any faster than your guardian angel can fly...
« Reply #7 on: July 10, 2009, 05:12:21 PM » |
Thanks!
Right there when you open the cap. Stanley Steamer (I think) said he found his screws to be loose (  ) and when he tightened them the gassy smell was gone/reduced... -Mike
junior
« Reply #8 on: July 12, 2009, 03:15:16 AM » |
i used to get the gas smell from the keyhole on the gas tank..........................till i stopped sniffing the keyhole
Stanley Steamer
« Reply #9 on: July 12, 2009, 04:28:56 AM » |
Thanks!
Right there when you open the cap. Stanley Steamer (I think) said he found his screws to be loose (  ) and when he tightened them the gassy smell was gone/reduced... -Mike screws loose???....  ........  ........ If those 2 screws are loose, then the cap doesn't close as tight as it should and must have allowed the gas fumes to escape....if mine ever starts smelling again, I'll add some more rubber to the gasket!!..
Stanley "Steamer" "Ride Hard or Stay Home"
« Reply #10 on: July 12, 2009, 08:16:04 AM » |
If you keep your bike out of the weather, the problem is pretty common and nothing to worry about.
Moving the bike out to the sun, the gas tank heats up and due to the expansion of the gas inside along with the ambient air inside the tank some will vent out in anyway it can.
Sloshing gas inside the hot tank will vaporize a bit of gas and do the same thing.
I don't give it any importance as it happens only occasionally.
