February 07, 2026, 11:32:26 AM *
Author Topic: Thrust washer  (Read 913 times)
rich_kildow
Spooner, WI
« on: August 18, 2013, 09:10:53 AM »
I think I have to many toys/hobbies and am starting to get the procedures for each messed up.  I have my rear tire off and am going to go ahead and pull the final drive/drive shaft to lube and inspect everything.  I see the plastic thurst washer that goes between the right side bearing face and the drive flange.  Now the question:  Is there anything special about the orientation of that washer?  I could have sworn I read something about a cupped washer in there somewhere and it needing to be oriented the right way, but that might have been a snowmobile or tractor or boat or reloading or...I don't know.
1998 Polaris XLT Touring
1990 Bayliner Cobra dual console
"The nation which forgets it defenders will be itself forgotten."  Calvin Coolidge
« Reply #1 on: August 18, 2013, 09:20:45 AM »
just coat it with a thin layer of grease, you cant put it on wrong, its just a flat piece of nylon
« Reply #2 on: August 18, 2013, 09:24:15 AM »
Don't think so.  It is a spacer.  A critical piece, but have seen them made out of a milk jug to get someone on the road while waiting on the part to come in.
Hay Cool
