February 07, 2026, 01:14:43 PM
Suspension squeak
Topic: Suspension squeak (Read 1110 times)
Hef
Opdyke, IL 62872
Suspension squeak
August 18, 2013, 09:01:03 PM »
I have a squeak in the rear when riding on a rough road. I don't think it's the shocks but don't know what else it could be. Any ideas?
Re: Suspension squeak
August 18, 2013, 10:02:40 PM »
Many valk drivers seats squeak, mine do. Including the driver's backrest.
Is your lower fender half loose/wiggly?
Michvalk
Remus, Mi
August 19, 2013, 08:15:55 AM »
Shock Bushings!
Farther
Quimper Peninsula, WA
August 19, 2013, 11:44:51 AM »
I was going to guess shock bushings too.
~Farther
August 19, 2013, 12:04:25 PM »
Some times you can find the squeak with a water pistol.
May simply be the brake pads!
Hef
Opdyke, IL 62872
August 19, 2013, 07:57:51 PM »
Shock bushings are new but if it is them then what's the fix?
Farther
Reply #6 on:
August 19, 2013, 08:24:05 PM »
I would put some plumber's waterproof silicone grease on them and if rubber, I would change them out to the polyurethane ones while you had them apart.
~Farther
JimmyG
Reply #7 on:
August 20, 2013, 06:49:07 PM »
I thought my rear suspension was squeaking, even squeaked when I bounced up and down on the stop. Come to find out , my strap that holds the tail pipe chrome cover on the exhaust had broken at the weld, and that was the thing squeaking. This is the second time the little strap has broken, hard to weld that thin metal.
