February 07, 2026, 01:15:08 PM *
Author Topic: Spline Lubrication / Other Issues during Tire Change  (Read 1710 times)
Stonecutter in SF
« on: August 19, 2013, 01:02:36 PM »
Hi all,
Another quick question - I'm getting my tires changed by a local mechanic I trust, but was wondering if there were any special instructions/issues I should mention to him when he gets the wheels off.  I remember hearing about the Splines needing lubrication - is this something I should indicate?  would he know how to do it?  Any other maintenance items i should ask of him when he's in there?  (also, whats better, dyna beads or ride-on?)
As an aside, I've had the bike garaged now for about a week due to the flat.  I've run it at idle twice every third day for about 5-7 minutes.  It's got about a 1/2 tank and the gas is untreated.  anything to be concerned about?
Thanks!
1999 Honda Valkyrie Standard
2009 Piaggio MP3 250ie
Tomos ST
1996 Suzuki Savage (RIP)
9Ball
« Reply #1 on: August 19, 2013, 01:36:36 PM »
yes, quit running the bike in the garage.  Add stabilizer or Seafoam to the fuel tank and make sure it gets to the carbs...you're doing more harm than good by starting the bike without riding it... tickedoff
Print out a copy of the Honda service manual with all the lube and torque requirements and take it with you to the mechanic.  If it is not lubed properly, if the 3 o-rings are not in good shape or replaced, and the thrust waher in place then you will not be happy when the final drive chews itself up before the next tire change.  There are specific requirements for re-installing the wheel to include the final sequence of tightening the final drive bolts that are very critical to this bike.
There are bike mechanics and then there are Valkyrie mechanics...they aren't always the same person.
Good luck...
« Last Edit: August 19, 2013, 01:40:01 PM by 9Ball » Logged
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
F6Dave
« Reply #2 on: August 19, 2013, 01:38:15 PM »
I wouldn't hurt to mention it.  But if he's worked on 1500 Wings or other Hondas with similar rear end designs he should know about it.
Stonecutter in SF
« Reply #3 on: August 19, 2013, 01:59:48 PM »
I have both the Clymer manual and a printed .pdf. of the owners manual.  Where can I look for the specifics?  don't want to take any chances.
Tomos ST
whitestroke
San Pedro, Ca.
« Reply #4 on: August 19, 2013, 02:10:38 PM »
This website is full of specifics. Read up for a few hours and you will know exactly what to and not to do. Search should get you lot of specifics.  Here's a start.
http://www.valkyrieforum.com/bbs/index.php/topic,43210.msg412850.html#msg412850
http://www.valkyrieforum.com/bbs/index.php/topic,53010.msg508478.html#msg508478
http://www.valkyrieforum.com/bbs/index.php/topic,53895.msg517945.html#msg517945
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
2 Kids 25 year break.
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
9Ball
« Reply #5 on: August 19, 2013, 02:27:27 PM »
The Honda service manual shows the thrust washer and moly paste requirements (including quantity) starting on page 14-7.  You don't have to worry about re-installing the rotor as you shouldn't have to remove it for just a tire change.  Page 14-8, Installation shows the additional moly paste lube requirements for the splines and the final drive and re-installation of the wheel with the torque sequence...
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Stonecutter in SF
« Reply #6 on: August 19, 2013, 03:23:15 PM »
I appreciate all the responses here.  I'm going to talk to my mechanic about his experience with large Honda cruisers (Goldwings, VTX etc.)  In case I don't feel confident he can do the job, does anyone have any info for trustworthy shops in Northern CA that service Goldwings/Valks?  I searched the forum and the only responses seem to be for SoCal / LA area.
Tomos ST
