February 07, 2026, 02:56:45 PM *
Author Topic: Shock Bushing Surprise  (Read 1617 times)
ZOOM
a hundred horsepower!!!
Genesee, WI
« on: August 19, 2013, 04:26:18 PM »
Took my shocks off to install my new Michelin Primacy and found both top bushings SHOT!!!!  Fortunately my local Honda Store had 'em in stock.  Had I not put the CT on,I would be riding with no bushings which my mother told me never to do!
CHECK YOURS!!
ZOOM
tonyfan70
Apparently they know you?
Central Illinois
« Reply #1 on: August 22, 2013, 08:21:05 PM »
Yep. Only bad thing is the Honda ones don't last all that long. I put new ones in when I mounted my new E3's. I recently lost a stem on the front tire and replaced the rear stem as well. I noticed when I took my shocks off that the upper bushings were already starting to deform and split. Nice, didn't even make it through a tire change.
1997 Standard. Original bumblebee tin stored.
1998 Magna 750
2000 POS Sportsman 500
CoachDoc
San Diego, CA
« Reply #2 on: August 22, 2013, 09:48:14 PM »
I'm waiting for new OEM bushings also. Is there an aftermarket alternative that will last longer?
CoachDoc
'97 Valkyrie Standard
'05 Goldwing
'74 CB550K
NiteRiderF6
Doug n Stacy
Mississippi
« Reply #3 on: August 23, 2013, 03:42:01 AM »
You can get some lifetime guaranteed shock bushings from this guy.... and he is a Valkyrie Rider's Vendor too:
http://xf6-custom.com/partpages/bushings.html
Farther
Quimper Peninsula, WA
« Reply #4 on: August 23, 2013, 08:15:16 AM »
The green VTX bushings are poly and last way longer than the stock Valkyrie bushings.
~Farther
ShiftHappens
South Suburbs Chicago, IL
« Reply #5 on: August 23, 2013, 08:28:03 AM »
I replaced mine earlier this year with regular OEM.
At $2.50 each, including shipping, I think the Honda Poly bushings (Part # 52489-HN0-671) is what I'd try next time.
http://www.directlineparts.com/product.asp?pid=44477
1999 Interstate
BradValk48237
Oak Park, MI
« Reply #6 on: August 23, 2013, 01:05:06 PM »
Ditto on the VTX bushings.... and I think they were cheaper!
B
KSDragonRider
Salina, KS
« Reply #7 on: August 23, 2013, 02:25:58 PM »
i got 2 pair of the vtx bushings for under 6 bucks for the pair.
Dalen & Shay -> Salina, KS
VRCC Member #33950
