November 25, 2025, 10:09:26 PM *
Author Topic: Valve Stem Change via the "C" Clamp Method???  (Read 2880 times)
Jetflyer
Vale, North Carolina
« on: August 21, 2013, 06:34:02 AM »
I purchased the Jake Wilson 90 degree metal valve stems to elleviate any OEM failure issues. I wish I had done this simple upgrade when I put on the new Avons. Now I have to back peddle.
I am trying not to go through the chore of removing the wheels from the bike. Has anyone had good success using the C clamp method to break the tire bead, and push it aside enough to get a new stem in place?
Thanks in advance for your replies.
« Last Edit: August 21, 2013, 06:44:16 AM by Jetflyer » Logged
I'm either driving a Valkyrie or an Airbus... it just depends on the day of the week.
« Reply #1 on: August 21, 2013, 06:47:05 AM »
I keep an 8 inch clamp and these two boards in my saddlebags...
I tested it, it works...
The boards are important... this didn't work, and even if it did, it would be bad
for any tire you wanted to keep using...
miscott
Keep the rubber side down and hang on tight!
So. Central Kansas
« Reply #2 on: August 21, 2013, 07:34:42 AM »
Yup, it worked for me too!
 In reading through through the past posts on the tech board, I also came across the ones about the solid metal 90* valve stems. Ordered some and following the pictures, I got a couple 8" C-clamps and went at it! The boards are important. Worked very well, I might add.
 Be sure and use a very small dab of the BLUE loctite. It'll keep those nuts secure and still allow for easy removal of the valve stem.
  The only problem I ran into was with re-seating the bead. a little soapy water will save you a big headache. I finally put a rachet strap around the diameter of the tire and tightened it up. You'll also need an air nozzle without the core in it to allow a full blast of air into the tire, so make sure you remove the core from the valve stem too. Don't ask how long it took me to figure that out!!  crazy2
« Last Edit: August 21, 2013, 07:36:28 AM by miscott » Logged
« Reply #3 on: August 21, 2013, 07:50:31 AM »
Once I used the ratchet strap method to seat a bead on a little yard tractor tire... when the bead popped
on, all of a sudden the strap was scary tight... be careful...
Thunderbolt
Worthington Springs FL.
« Reply #4 on: August 21, 2013, 02:04:28 PM »
In Mike's first picture if you will turn the bottom board 90 degree's so that it contacts the rim and the tire at the same time it will break only the top bead.  That's all you need to do.  I did it in a parking lot at a motel recently, and it worked very well.  That way you only need to reseat the side that you unseated to put in the new stem.   Just wet the tire with a soaked rag and if necessary sit the bike down on that section or use the strap method.
Jetflyer
« Reply #5 on: August 21, 2013, 05:02:13 PM »
Thank you for the advice thus far...
The front tire seems doable, leaving the wheel on the bike. Would you guys attempt this DIY technique on the rear wheel of a Tourer, with the bags in the way too?
« Reply #6 on: August 21, 2013, 05:10:55 PM »
If you have a big enough C-Clamp to get the job done on the rear, the bags should not stop you.  Id have the bike on a lift though so the wheels are off the ground for sure
Jetflyer
« Reply #7 on: August 21, 2013, 05:16:26 PM »
It will be on a lift. I forgot to mention that. Tidbits of wisdom are always appreciated!!!
« Reply #8 on: August 22, 2013, 05:54:12 AM »
Cant u pull out the old stem and push the new one in without tearing the tire apart? I looked at my jake wilson stem and it looks like you can. Unless I'm missing something.
cantom
Ontario
« Reply #9 on: August 28, 2013, 02:17:16 AM »
The tire has to be moved to one side so you can access the valve from the inside...the new stem gets pushed through from the inside, no way to do that with the tire still in place with seated beads.
« Reply #10 on: August 28, 2013, 07:10:31 AM »
You could use a hole saw to make an access hole in the tire just below the valve stem, but I wouldn't recommend this method, the tire is prone to leakage after the stem is installed.  Evil  Evil
Brian
Monroe, NC
« Reply #11 on: August 30, 2013, 07:18:41 PM »
I tried using two 8" clamps from Sears with wood blocks. The clamps would move off the blocks as they were tightened. I ended up taking the wheel to the bike shop. They installed my new valve for $15. Maybe this winter when I do the drive line maintenance I will try it again.
cantom
Ontario
« Reply #12 on: August 31, 2013, 04:00:09 AM »
I am thinking about using a woodworking drill spade bit to make a couple of circular cuts into the wood pieces, just deep enough to keep the C Clamp from sliding off as you tighten it up. Anyone tried that?
« Reply #13 on: September 01, 2013, 06:15:28 AM »
That sounds like a good idea cooldude
You'd want to use 2X stock so the clamps seats (?) won't punch through the blocks.
chauffeur
Mansfield, Texas
« Reply #14 on: September 01, 2013, 09:17:45 AM »
I was the fortunate recipient of Thunderolt's generosity in the hotel parking lot.  Took all of 15 minutes to get her done and that included planning and strategizing.  Thanks again, fine sir.
