February 07, 2026, 02:56:51 PM *
Author Topic: Crush washers  (Read 1460 times)
Bronxboy
Tampa Bay FL
« on: August 21, 2013, 05:50:16 PM »
Where do u guys get the crush washers for the oil & gear  drain plugs? is there a part number or just the hardware store?
« Reply #1 on: August 21, 2013, 05:57:05 PM »
Directline usually.
http://www.directlineparts.com/product.asp?pid=4744&str=0&mdl=1539&mdy=1997
Grandpot
Fort Mill, South Carolina
« Reply #2 on: August 21, 2013, 06:09:34 PM »
Go to any auto parts store and ask for 14mm drain plug crush washers.  Get a dozen, there're cheep.
Bronxboy
Tampa Bay FL
« Reply #3 on: August 21, 2013, 06:12:40 PM »
FLAVALK
Winter Springs, Florida
« Reply #4 on: August 21, 2013, 06:13:50 PM »
hmmmm..... not sure I've ever changed mine.
« Reply #5 on: August 21, 2013, 06:16:32 PM »
Me either!  cooldude
« Reply #6 on: August 21, 2013, 09:20:31 PM »
In 136K I think I replaced one on the engine.
« Reply #7 on: August 22, 2013, 06:19:35 AM »
Me either!  cooldude
me 3
« Reply #8 on: August 22, 2013, 06:20:51 AM »
4!
F6Dave
« Reply #9 on: August 22, 2013, 07:03:54 AM »
My Tourer has 167,000 miles and I finally replaced the oil drain washer at my last oil change.  It was starting to get a bit worn.  I didn't feel like driving to NAPA so I just found a washer in my parts drawer that fit.  I'm probably good till over 300K now.
Bronxboy
Tampa Bay FL
« Reply #10 on: August 22, 2013, 09:36:59 AM »
Picked up a pak of them at Advance Auto. I will change them next time around.
« Reply #11 on: August 22, 2013, 09:48:16 AM »
I take them out of our inventory.
Change oil at the shop, so I might as well use our supplies.
Farther
Quimper Peninsula, WA
« Reply #12 on: August 22, 2013, 11:36:39 AM »
I change mine everytime because they take a set.  Purchased in bulk from H&A Honda online.
http://www.handa-accessories.com/elementmaint.html
~Farther
biguglyman
Brockport, NY
« Reply #13 on: August 22, 2013, 12:45:18 PM »
Mine looks like there are three or four all crushed together on it. Doesn't leak though...
big poppa pump
San Antonio, TX
« Reply #14 on: August 23, 2013, 12:10:09 PM »
Cheaper to pick up crush washer from your local Honda car dealership. The same washers are used on both the bikes as well as the cars. My local motorcycle stealership charges $0.99 for a single crush washer. I can get the same thing at the car dealership for $0.30.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
