February 07, 2026, 01:14:58 PM *
Author Topic: Main jets don't kick in?  (Read 1102 times)
Hoosier Valk
Indianapolis, IN
« on: August 21, 2013, 08:19:28 PM »
1999 Valk Standard - runs rough, won't idle without choke on almost all the way. Won't rev over 3,000 rpm's under load. Cleaned all the jets, 3 slow jets clogged and all mains looked good. Back together runs smooth and idles with no choke but the mains don't kick in. Also replaced cracked and leaking hoses. Any ideas? Thanks in advance.
« Reply #1 on: August 22, 2013, 03:49:59 AM »
Did you clean the whole carburetor or just the jets ? It sure sounds as if a circuit or 2 or 3 is plugged. How are the diaphrams and needles ?
Pete
« Reply #2 on: August 22, 2013, 05:57:08 AM »
Based on your description the pilot circuit is working fine.
It sounds like the main circuit is either not getting air or gas in the right amount.
After running to 3000 rpm, hold it and let it shut off, are the plugs gassed or clean?
If clean, no gas, if gassed no air.
Sound like no gas, either because the main gas circuits are partially plugged or the carb pistons/slides are not raising in the bores, due to binding or lack of vacuum to raise the carb pistons/slides.
« Reply #3 on: August 22, 2013, 08:17:40 AM »
This is most likely where the problem lay.
The mains are a straight shot right up to the venturi area of the carburetor so being plugged up would mainly be at the jet which is the restricted passage way and an easy clean.
Of course the assumption of it being a main jet problem falls fully on the expertise of the (OP's)analysis.
« Reply #4 on: August 22, 2013, 04:00:25 PM »
bad petcock vacuum diaphragm, tank vent hose blocked/kinked, in-tank fuel filter sock clogged, carb bowl vent hoses blocked/kinked.
« Reply #5 on: August 23, 2013, 07:46:42 AM »
Good points. I assumed that all that was checked, but, you what happens when you assume.
