February 07, 2026, 01:15:06 PM *
Author Topic: Triple tread rubbing  (Read 1278 times)
hillbilly
Chapmanville WV
« on: August 22, 2013, 07:52:04 PM »
Just installed my 3rd. triple tread 205/60/16, tread looked a little different from the last one.  Put 1st on in 2008/ last tire on in 2011 neither one rubbed. this one rubs slightly. Anyone know of a fix, maybe a 2nd. thrust washer? Will it wear off?
Michvalk
Remus, Mi
« Reply #1 on: August 23, 2013, 05:37:32 AM »
Did you check wheel bearings when the wheel was off? cooldude
Valkpilot
What does the data say?
Corinth, Texas
« Reply #2 on: August 23, 2013, 06:25:36 AM »
What is it rubbing against?
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #3 on: August 23, 2013, 09:39:18 AM »
I'm guessing on the swing arm.
hillbilly
Chapmanville WV
« Reply #4 on: August 23, 2013, 02:00:36 PM »
Yes checked bearings they felt good. Tread design looked different from last tt put on in 2011, it was close before but never rubbed swing arm. I can spin wheel by hand but it's definitely rubbing. Wondering if anyone else has recently put one on and had this problem?
hillbilly
Chapmanville WV
« Reply #5 on: August 23, 2013, 02:01:24 PM »
Swing arm
moxmiff
« Reply #6 on: August 23, 2013, 04:51:19 PM »
   I just purchased my first one today from tirerack 205/60/r16 Hopefully it will not rub, Never have gone to the darkside but i am tired of putting on tires that don't last! We Will See
Michvalk
Remus, Mi
« Reply #7 on: August 23, 2013, 07:40:22 PM »
I put a 205/60 on mine, and it didn't rub, but, would knock the dust off the sidewall. Could not slip a credit card between the swingarm and the tire, but, never did actually touch the tire. Some tires do that and some don't. If it is actually is touching, I wouldn't run it. You might get the clearance you need by inflating a little more, or loosen everything up, and retorque everything in the proper sequence. cooldude
hillbilly
Chapmanville WV
« Reply #8 on: August 23, 2013, 07:44:35 PM »
You should be fine and I think you'll love the tt. I took mine back off this evening and found the source of my rub. There are 2 thin flat plates welded on the drive shaft tubing, one of these plates was bent out, took a hammer and tapped it tight against the swing arm , tire no longer rubs. Thanks for everyone's input. Hillbilly
PhredValk
Edmonton, Alberta, Canada
« Reply #9 on: August 23, 2013, 11:38:56 PM »
Put some masking tape on the swingarm, inside fender etc and go for a hard ride. The tape should tell you where it's rubbing.
I have over 27K miles on my Falken, and it has always rubbed. Not all the time, I figure it hits while turning left or right, or on hard bumps. I worried about it at first, but after all this time I don't care anymore. It's just a dark black 'clean' patch all around the tire.
Fred.
VRCCDS0237
