February 07, 2026, 01:15:03 PM *
Author Topic: Brake pads,  (Read 890 times)
2qmedic
Simply Awesome!!!
« on: August 27, 2013, 09:34:17 AM »
Greetings all,
Its time for some new brake pads on the Valk. In compairson front vs rear, I have looked and it appears the only difference is just the thickness of the actual pad itself. The rear pad material is a bit thicker, but they are also less expensive...
Besides a super tight fit, does anyone know any reason why the rear pads will not work on the front?
 Smiley
« Reply #1 on: August 27, 2013, 09:50:55 AM »
As far as I know the rears will fit the front as long as you take some sandpaper to them to make them skinny enough to fit.
I've not tried it though, I just buy the right ones. I also prefer the OEMs rather than EBCs which seems to be what the Honda dealers around here want to sell you.
