February 07, 2026, 01:14:55 PM
Removing Tank Emblems
Topic: Removing Tank Emblems (Read 1093 times)
Hef
Opdyke, IL 62872
August 29, 2013, 11:19:28 AM »
My Valkyrie is a 2000 Standard.
I have questions for those of you who have removed your tank emblems.
1. Are the emblems glued on?
2. Is the tank indented behind the emblem or is it flat?
3. Does removing the emblems require re-painting the tank?
Thanks for any help with this.
Hef
Re: Removing Tank Emblems
August 29, 2013, 11:30:20 AM »
Glued with double sided tape.
No. Curved like tank.
Not unless you get abusive.
Warm them up with a hair dryer and carefully pull/saw fishing line or dental floss behind them (once you get it started, spray some WD40 back there), clean up residue.
Last Edit: August 29, 2013, 12:01:03 PM by Jess from VA
Jack B
Two Rivers Wis
August 29, 2013, 05:14:46 PM »
And when you get the emblems off sent them to for safe kepting.
Let’s RIDE
August 29, 2013, 05:20:37 PM »
You might want to wear some gloves, cuz pulling on that fishing line kinda cuts into the flesh on the fingers.
58Woody
Chanhassen , Mn.
August 29, 2013, 05:30:37 PM »
Is it better to do the heating with a low tank of fuel?
(I was thinking that the liquid would absorb a lot of the heat and make it take longer.)
Be not afraid. Only believe.
rdfaulkner
August 29, 2013, 09:12:02 PM »
And most importantly, be sure and post pics of the finished product.
rich_kildow
Spooner, WI
Reply #6 on:
August 30, 2013, 07:57:38 AM »
I would do it with a low tank for exactly that reason. And post pictures!!! I like the idea of having no emblems and am more than willing to let you take the plunge first.
1998 Polaris XLT Touring
1990 Bayliner Cobra dual console
"The nation which forgets it defenders will be itself forgotten." Calvin Coolidge
