February 07, 2026, 02:56:48 PM
Need Idea's for Exhaust Tips
Topic: Need Idea's for Exhaust Tips (Read 1093 times)
dan7uk
Louisville, Kentucky
August 29, 2013, 12:15:46 PM »
Currently have OEM exhaust with piggy's on a 99 Tourer. Wanting to remove just the OEM tips and install round tips cut at a 45 degree at end to extend just beyond the hard bags. Is there a exhaust tip out there that fits this description and will mount in place of OEM and still keep the piggy's in tacked. Pic's would be nice if someone has this setup and did it change the exhaust note, like the factory sound. Thanks.
blackpearlghost
Re: Need Idea's for Exhaust Tips
August 29, 2013, 12:24:46 PM »
http://store.airflo.com/chrome-exhaust.html
August 29, 2013, 12:25:53 PM »
http://www.airflo.com/valkyrie.html
http://store.airflo.com/af420-418hs.html
18" flat cuts extend just past the bags an inch or a bit more. The mitre cuts will too if angled down, not up.
http://store.airflo.com/af40-418hs.html
August 29, 2013, 01:10:17 PM »
Is there some airflo set you can get, keep the piggies and put on a set of Grumpy's tips?
-Mike "always wondered if all that would work together..."
jmann
Mesa,Az.
August 29, 2013, 03:44:43 PM »
I have the 18" flat cut with piggies and grumpys. Work great. Look even better.
August 29, 2013, 03:54:47 PM »
Quote from: jmann on August 29, 2013, 03:44:43 PM
YoungPUP
Valparaiso, In
Reply #6 on:
August 29, 2013, 05:19:01 PM »
Cobra made tips for our bikes, 45 deg slash cuts. but aside from the set I got during a parts room clean out from my local dealer, I've never seen another set.
99 STD (Under construction)
