February 07, 2026, 04:42:07 PM *
Author Topic: front forks  (Read 1419 times)
Art708
Jacksonville, FL
« on: August 31, 2013, 12:00:38 PM »
  So ... today I went to put new fork seals in my bike. I jacked it up , removed the calipers, loosened the left side pinch bolts, loosened one right side pinch bolt, and rounded out the hole on the other one 'cuz it was so tight. I took a hammer and drove in an SAE larger hex and promptly rounded the hole out with that one too.  Said screw it...put the calipers back on, tightened the pinch bolts back.  Unscrewed the fork cap on the side that had the bad leak (that I got stopped with the SealMate) and poured in about 8 ounces of oil and put the cap back on. Now the bike rides soooo much better. I was looking for bumps to ride over just to feel how good it worked. I may not have the exact right amount of oil in the fork but it sure is riding a whole lot better. Maybe at some later date I'll figure out how to get that pinch bolt out and change seals and put the proper amount of oil in.
Art
 2014 Kawasaki Concours 14
  Black
« Reply #1 on: August 31, 2013, 05:46:21 PM »
I have a set of these, work better on allen heads. You have to drill the hole a bit deeper so the extractor doesn't bottom out, then tap the extractor into the hole and use a wrench to turn it. The picture doesn't show it very well, but each one has a series of sharp edges that catch real good, better than the screw shaped ones.
http://www.sears.com/craftsman-5-pc-screw-extractor-set/p-00952315000P?prdNo=4&blockNo=4&blockType=G4
Art708
Jacksonville, FL
« Reply #2 on: August 31, 2013, 06:36:20 PM »
 John, I have a set of those somewhere. I was looking for them this evening but haven't found them yet. If I can't find them I'll go to the store Monday or Tuesday and get some.  Thanks .....
Art
  Black
sutterhome
« Reply #3 on: September 01, 2013, 09:56:00 AM »
you just put the oil in from the top?always wondered if this was doable.
Art708
Jacksonville, FL
« Reply #4 on: September 01, 2013, 11:27:32 AM »
 Sure it's doable.....you just don't know how much you have in the fork if you don't drain and refill with the proper amount.
Art
  Black
Daniel Meyer
The State of confusion.
« Reply #5 on: September 01, 2013, 11:38:02 AM »
On the stuck pinch bolt...tighten the OTHER one up before attempting to get the bad one out again. Takes the pressure off.
CUAgain,
Daniel Meyer
« Reply #6 on: September 01, 2013, 11:45:02 AM »
+1 except....is it the single one or the tree with two pinch bolts? If the larger single one he might still have trouble. Can't tell by the post but I'm led to believe it is the tree with two bolts.
Daniel Meyer
« Reply #7 on: September 01, 2013, 01:04:28 PM »
I read it as the axle pinch bolts.
CUAgain,
Daniel Meyer
Art708
Jacksonville, FL
« Reply #8 on: September 01, 2013, 01:09:46 PM »
Right Daniel....axle pinch bolts.  I already tried tightening up the loosened one then trying the other one....no joy. I am good for now but I will work on getting the rounded out one loose. I do want to change seals and put in the proper amount of oil before too much longer.
Art
  Black
« Reply #9 on: September 01, 2013, 03:16:18 PM »
OK, I sit corrected. Thought you were talking about the pinch bolts on the trees. There I go....thinking again.  Grin
hager the horrible
florence co
« Reply #10 on: September 05, 2013, 07:24:29 PM »
May want to take care of sooner than later what if you have a flat tire now you got a tow bill for sure.
Also have you tried taking the other 3 pinch bolts loose and use a brass drift to remove axel once Adelaide is free there should be zero tension on tensing pinch bolt
