February 07, 2026, 02:57:03 PM *
Author Topic: Gas leak  (Read 991 times)
trikerron
falls city ne.
« on: August 31, 2013, 06:43:40 PM »
Sometimes when i start my Valkyrie i have gas leaking out of fuel hose where it connects to the fuel valve and sometimes it will not leak. It only leaks when it is runnig.
RON
« Reply #1 on: August 31, 2013, 07:15:34 PM »
May not be tight enough on the nipple. Try using a screw type hose clamp instaed of the cheap one that was on it from factory. Unless you are already using that type. Could also be a hole in the hose or petcock needs rebuilt Iif still using oem.
« Reply #2 on: August 31, 2013, 08:10:09 PM »
are you sure its coming from the hose and not that little weep hole at the bottom of the valve.........that means rebuild time or just get a good fuel valve
