January 29, 2026, 03:36:41 AM *
Author Topic: Acetone in fuel  (Read 3181 times)
Sludge
Toilet Attendant
Roaring River, NC
« on: July 11, 2009, 08:06:18 PM »
Has anyone used a small amount of acetone (.75 oz or so) per tank in their valks?  I was thinking about testing this on my supercharged bike.  I have talked to folks and read about how it breaks the surface tension of the fuel to allow for better vaporization.  Resulting in a somewhat better fuel mileage and performance increase.
Any experimental valk riders out there that have tried this?
"We have two companies of Marines running rampant all over the northern half of this island, and three Army regiments pinned down in the southwestern corner, doing nothing. What the hell is going on?"
Gen. John W. Vessey, USA, Chairman of the the Joint Chiefs of Staff during the assault on Granada
T.P.
Apple Valley, Minnesota.
« Reply #1 on: July 11, 2009, 08:38:51 PM »
http://www.snopes.com/autos/techno/acetone.asp
Sludge
Toilet Attendant
Roaring River, NC
« Reply #2 on: July 11, 2009, 09:09:57 PM »
Snopes opinion aside... I may try this at some point.  I don't have 6 carbs to worry about.  So rebuilding one isn't such a chore if things go the wrong way Smiley  A few before and after 1/8th mile runs should be a good indication of whether it has effected performance since I don't have a MC dyno handy where I live.
junior
new hampshire
« Reply #3 on: July 11, 2009, 09:14:38 PM »
acetone will eat your o rings and anything elese plastic that aint nylon
Sludge
Toilet Attendant
Roaring River, NC
« Reply #4 on: July 11, 2009, 10:05:02 PM »
Less than an oz in 4gal?   Still... Ill try it.
T.P.
« Reply #5 on: July 11, 2009, 10:11:36 PM »
http://www.cartalk.com/content/columns/Archive/2006/January/08.html
« Reply #6 on: July 12, 2009, 08:19:47 AM »
Toluene is a better thing to add. Especially in performance machines.
Scanner
Tacoma, WA
« Reply #7 on: July 12, 2009, 11:32:16 AM »
...why did he ask if doesn't care what the answer is?
Reality - it's nice here, come visit sometime!
« Reply #8 on: July 12, 2009, 12:11:56 PM »
Tried it DOESN'T WORK uglystupid2
« Reply #9 on: July 12, 2009, 12:53:24 PM »
acetone has about the same BTU content as ethanol. Gasoline has the highest BTU content and is therefore the best for fuel efficiency.
acetone is used in methanol/gasoline mixes to stop phase separation when water gets into the mix, which happens since the alcohol fuels tend to be hydroscopic.
ethanol has less phase problems, less corrosive, and mixes better with gasoline than methanol.
acetone has no other benefit being added to gasoline.
DeathWishBikerDude
« Reply #10 on: July 12, 2009, 02:28:03 PM »
I doubt a few ounces mixed with 5 gallons of fuel,is going to eat up o rings.
I use a few ounches of A1 kerosene every once in a while to keep my carbs clean.
 coolsmiley
Sludge
Toilet Attendant
Roaring River, NC
« Reply #11 on: July 12, 2009, 03:11:13 PM »
If you look closely at my post, I was asking if any one HAD experience with it and thus a opinion of their own not quoted from another source.
I really don't care about a MPG increase, though I would take it if I could get it.  I just wonder if it would actually give better atomization of the fuel thus a more complete burn of your fuel.  Perhaps a slightly better performance.
Im just curious.  I may go ahead and set up a test.  Perhaps fill the bike and ride a 100 mile circuit and re-fill at the same station and then add the acetone and ride the same circuit again and re-fill at the same station and compare the mileage.  Maybe do 10 1/8th mile runs without it and then do 10 runs with it and compare the average speeds, standard deviation, etc.
« Reply #12 on: July 12, 2009, 04:27:50 PM »
I've no experience with acetone in gasoline but if acetone will cause damage to o-rings and seals it doesn't matter how dilute the acetone is.
It would be fallacy to expect that a dilute solution of acetone would be harmless. It would just take a longer time to do the damage.
The acetone doesn't change with dilution. It's still acetone.
alph
Eau Claire, WI.
« Reply #13 on: July 12, 2009, 11:19:04 PM »
exactly.  i would sugest it to a harley guy first and see what happens!!  wouldn't even consider it in my bike!
Piper
San Antonio
« Reply #14 on: July 13, 2009, 12:15:01 AM »
[/quote]
You might want to try a brown gas generator. I have not heard of installing one on a bike but I guess it could be done. Co-worker built a DIY from parts from the local big-box-hardware store and installed it in his 4x4. Said he got -some- mileage improvement, but not any performance inprovement. Search on the web for brown gas generators. More info yea/nea than you can shake a stick at.
Things we tried when I was a kid:
Acetone in a Vega: ate everthing plastic between the tank and the carbs. What a mess. Though we might have added a bit too much. uglystupid2
Liquid ether in a Chevy PU. Supposed to raise octaine. Not much happened, exhaust smelled funky
Old style mothballs in the same Chevy PU. clogged the filters, really funky exhaust. Again not much if any improvement.
Now these were not precision tests on top running vehicles, just a bunch of farm boys trying to get their clunky cars to run faster. Had to switch to the farm truck 'cuz the Vega was out of action for awhile.
Uncle was a bit tick'ed about his truck.
Now the newer vehicles are supposed to have solvent resistant plastics. I for sure would not tempt fate again. It was a lot of work to get that Vega running again.
Never in my Valk.
Nor my Dodge for that matter.
~   /  And it's whispered that soon, if we all call the tune
  0/// Then the piper will lead us to reason
<|o>  And a new day will dawn for those who stand long
 /_\    And the forest will echo with laughter
John G.
SC
« Reply #15 on: July 13, 2009, 11:20:59 AM »
This kinda sounds like the ole darkside discussion.
Pappy told me one time that graveyards and jails are full of people who put things in places they weren't suppose to.
Sludge
Toilet Attendant
Roaring River, NC
« Reply #16 on: July 13, 2009, 04:04:23 PM »
LOL, yea it is kinda like a darkside/oil thread isnt it.    Grin
It has captured a bit of my curiosity.   A test may be in order, but I doubt no matter the outcome that I will start using that regularly.
franco6
Houston, TX
« Reply #17 on: July 13, 2009, 07:46:03 PM »
 ;Dwhen i was a kid ,a long time ago ,  we would put ether in the gaz tanks ,that did the trick, more power. of course there :uglys were a few blown engines too! uglystupid2 2funny
Enjoy the ride!
Ferris Leets
Catskill Mountains, N.Y.
« Reply #18 on: July 14, 2009, 06:29:11 AM »
I did a really extensive test of acetone on my Nomad.  About five different concentrations, several hundred miles.  My results were no significant change.  No damage but no improvement.  I still have the spread sheet if anyone is interested.
Sludge
Toilet Attendant
Roaring River, NC
« Reply #19 on: July 14, 2009, 08:22:43 PM »
Thanks for the info Ferris.
BTW folks, this is the kind of response I was looking for.  Roll Eyes
