February 07, 2026, 06:34:00 PM *
Author Topic: Nut cage mod question,,,,  (Read 1074 times)
Varmintmist
Western Pa
« on: September 06, 2013, 10:35:16 AM »
1. (Oss) Doing the nut cage mod for the battleax 200, did you:
Just take the cage?
Go all out and get a SS carriage bolt?
2. (anyone) Just to satisfy my customizing redneckery..
Is there any reason why one could not hone the square nut a bit thinner? Will likely replace
Churchill
TJ
Lake Placid , Fl.
« Reply #1 on: September 06, 2013, 11:14:19 AM »
All I have ever done is cut the cage off....  running car tire....
Varmintmist
Western Pa
« Reply #2 on: September 06, 2013, 11:39:39 AM »
I like that even better, KISS it.
Churchill
« Reply #3 on: September 06, 2013, 01:54:35 PM »
I cut the cage off, smoothed everything down, dabbed a little paint, and put it back the same way but with a skinny nut.  Probably could have used the fat nut, but didn't...
BonS
Blue Springs, MO
« Reply #4 on: September 06, 2013, 02:19:16 PM »
I cut the cage off and kept the square nut but it still rubbed my CT. Substituted a carriage bolt: done.
I suppose you could cut down the square nut but it's probably a lot easier to buy a jam nut which are thinner versions of hex nuts. If you have or will have a trailer hitch I'd rather have more threads engaged than will result from a jam nut or shaved square nut.
quexpress
Montreal, Québec, Canada
« Reply #5 on: September 07, 2013, 11:45:44 AM »
I did mine ages ago. It's been so long that I had to check.
You can see it here if you wish.
http://www.quexpress.02hosting.com/quexpress/Valkyrie/fender_bolts.htm
I still have a full deck.
I just shuffle slower ...
fantsybikr
O HI O
« Reply #6 on: September 07, 2013, 02:22:44 PM »
Just take the cage?
I actually did grind my square nut thinner when I did my standard in 07, and have had no problems..but technically not a good idea as thread engagement should be the same as the diameter of the bolt to ensure proper strength..just did my IS this summer and used a button head bolt.
VRCCDS 0252
  VRCC   26284
 GWRRA 329832
