November 25, 2025, 09:56:49 PM *
Author Topic: Rear brake problems 1999 Tourer  (Read 1169 times)
« on: September 06, 2013, 03:41:04 PM »
I had to replace wheel bearings in the rear wheel, pulled the wheel, got that done.  When reassembled the brakes will not fully release.  Result, super hot rotor.  Before I get started, is there anything I should or should not know?  I hate working on brakes, btw.  Hoser   Angry Angry  (Update posted below.)
« Last Edit: September 13, 2013, 06:01:29 PM by Hoser » Logged
« Reply #1 on: September 06, 2013, 05:18:24 PM »
Hoser-when mine locked up-rear brake-in the garage and after I got it tore down the exposed parts of the pistons were very NASTY. Needed compressed air to get the pistons out Scotch Brite on the nasty part of the pistons new O-rings-good to go.  cooldude So yeah what i'm saying is rear caliper rebuild.  crazy2 RIDE SAFE.
« Reply #2 on: September 06, 2013, 08:09:50 PM »
Sounds like your pistons need cleaning.  You can remove the caliper w/o pulling the wheel by removing the pin bolt.  PITA, but the results are worth it.  Just did one of mine and piece of mind is good. cooldude
blackpearlghost
« Reply #3 on: September 08, 2013, 02:07:15 PM »
I had a customer's rear brake lock up after I finished going through his bike.  Turned out to be the rear master cylinder.  There is a return hole, extremely tiny, that was clogged with debris. Removed it from the bike and I used a piece from the smallest string of a guitar to clean it out.  Worked like a charm.  Of course, cleaned all components thoroughly and purchased a rebuild kit.
« Reply #4 on: September 08, 2013, 03:35:07 PM »
Looks like caliper rebuild is due, I will let cha know how that works out.  Hoser  Shocked
« Reply #5 on: September 08, 2013, 04:00:20 PM »
Pretty easy if you have the right size snap ring pliers.  Sort of hard to put the rubber over the end of the plunger, but a little brake fluid helps a lot.
Hay  Cool
JImmyt
« Reply #6 on: September 08, 2013, 05:40:35 PM »
Hay  Cool
JImmyt
I took the caliper to a good independent shop that I use. I know my limitations!   Shocked Shocked  Hoser
« Reply #7 on: September 13, 2013, 05:59:41 PM »
Update:  A new push pin and push pin bushing got the fatlady on the road again.  Smiley  Hoser  Wink
« Reply #8 on: September 15, 2013, 05:14:48 AM »
just one question.......What if you know something you shouldnt?  Would you try to un-know it then or what next?
« Reply #9 on: September 15, 2013, 05:28:32 AM »
Turns out I should know better than play with something I am not familiar with. (the rear brake caliper)  Shocked  Hoser
