January 29, 2026, 02:13:20 AM
Throttle Side Cable Connection Help
Topic: Throttle Side Cable Connection Help (Read 2023 times)
RUDE DOG - Steelers
New Jersey - VRCC # 3966
July 12, 2009, 01:21:20 PM »
Installing my new Drag Bars and Grips. When connecting the cables to the grip inside the housing, which cable connects where? If they just hook up to the closest point, then I seem to have too much cable on one. Anyone have a picture or diagram of how the connect to the grip? How can I adjust that or tighten it up? Please dont tell me I need new cables.
Last Edit: July 12, 2009, 01:31:55 PM by STEELERS
DeathWishBikerDude
Re: Throttle Side Cable Connection Help
July 12, 2009, 02:24:47 PM »
Visit dags site and download the manual.
There is an adjustment for the cables.
http://www.valkyrienorway.com/
RUDE DOG - Steelers
July 12, 2009, 03:59:18 PM »
I have the manual on CD. Will check it out. Hopefully it shows how the cables connect to the grip.
DeathWishBikerDude
July 12, 2009, 04:06:39 PM »
The throttle side has a tube that slips onto the handlebars.
This tube accepts the throttle cables,and your grips should fit onto the tube.
You need grips especially made for the valkyrie,as they don't come with the tube.
RUDE DOG - Steelers
July 12, 2009, 06:37:14 PM »
I installed new bars and grips so Im not using the tube. I just have to grind the housing opening down a little to fit the new grips. No tube needed.
DeathWishBikerDude
July 12, 2009, 07:09:13 PM »
You need the tube to actuate the throttle cables.
The housing just protects the cables from the elements.
You need the tube.
RUDE DOG - Steelers
Reply #6 on:
July 13, 2009, 12:21:04 AM »
The new grips already have the round spots where the cables attach built on to them. No plastic sleeve needed.
Reply #7 on:
July 13, 2009, 07:31:53 AM »
You might want to check where the cable rides on the sheave under the tank. It can slip off and cause you to seem to have a lot extra inside cable length.
