February 07, 2026, 04:42:22 PM *
Author Topic: Heated elements with stock grips?  (Read 1328 times)
maniscar
VRCC #2225
Southern NH
« on: September 09, 2013, 05:05:13 AM »
Hello,
Not sure if this is a Tech Board question, so I apologize in advance.  But has anyone used the OEM grips with these heated elements?
If so, did you trim, or notch out, the chrome edge, i.e. where it meets the switch housing?
Note: I already have these heated elements so not interested in the "all-in-one" heated grips.   Smiley
  Rich
2003 Valkyrie Standard
BlueValk
Albuquerque, NM
« Reply #1 on: September 09, 2013, 09:19:10 AM »
I used something similar.  They worked well, but did not last very long (1 season).  I am now using heavy duty block warmers.
As to your question, you shouldn't need to notch anything.  I roll the heater around the grip (the narrow direction) between the chrome pieces so that the wiring is under the grip.  You'll feel it and know it is there, but it is not a big deal.
I wrap bicycle inner tubing over the heaters to hold them in place.  Looks okay.
maniscar
VRCC #2225
Southern NH
« Reply #2 on: September 09, 2013, 11:00:21 AM »
Thanks BlueValk.  Not sure I understand.  Did you put the heated element on top of the OEM grip and cover it with bike tube?
 Is that the grip or the bike tube rolled back?
BlueValk
Albuquerque, NM
« Reply #3 on: September 09, 2013, 11:35:26 AM »
Yes, they are rolled on top of the OEM grips.  And yes, that is the inner tube rolled back.
maniscar
VRCC #2225
Southern NH
« Reply #4 on: September 09, 2013, 11:55:14 AM »
Ok, thanks.  I'll keep that solution in mind.  I'm still curious though if anyone put them under the grips and how they dealt with the chrome trim.  Smiley
cutter
Plantersville, Texas
« Reply #5 on: September 10, 2013, 06:30:38 AM »
I picked up some grip heaters from an ATV shop that worked for several years. They went under the OEM grips and I didn't have to notch the chrome. They came with a toggle switch with a high, off and low setting.
maniscar
VRCC #2225
Southern NH
« Reply #6 on: September 10, 2013, 10:06:29 AM »
Thanks cutter.  So, you just left a gap between the wires and the chrome trim?
maniscar
VRCC #2225
Southern NH
« Reply #7 on: September 10, 2013, 10:07:33 AM »
Sorry, I meant to say "a gap for the wires between the chrome trim and switch housing?"
miscott
Keep the rubber side down and hang on tight!
So. Central Kansas
« Reply #8 on: September 10, 2013, 10:56:07 PM »
  What Cutter said sounds like what came on my Valk when I got her. Yeah, there's a gap between the Chrome Trim and the Switch Housing, just wide enough for the wire, but it's only maybe 3/16". Can't hardly notice it unless your looking for it. Got the toggle switch mounted in my center cover under the seat. Low, off, high.
maniscar
VRCC #2225
Southern NH
« Reply #9 on: September 11, 2013, 05:19:51 AM »
Sounds good.  Thanks.
cutter
« Reply #10 on: September 11, 2013, 08:12:21 AM »
What Miscott said. I left a little bigger loop ( if that's what you'ld call it) on the throttle side so it wouldn't bind when I twisted that grip.  2funny Then I just zip tied it to the rest of the cables.
maniscar
VRCC #2225
Southern NH
« Reply #11 on: September 11, 2013, 12:21:59 PM »
Thanks!  Good to know.  Will give it a try this weekend.
