February 07, 2026, 04:43:41 PM *
Author Topic: New life to old windscreen  (Read 1717 times)
Christbiker
Anna, TX
« on: September 09, 2013, 06:17:46 PM »
Not really tech related but thought I'd share.  Just bought a '99 IS and the windscreen (W/S) was horrible and unsafe.  Previous owner must have repeatedly dried in with a hard dry abrasive cloth.
Thinking I can't make it any worse I experimented with the following with fantastic results.
Warm soap and water entire w/s  (I left mine on the bike) semi dry with damp cloth
Put a thick film of GooGone spray gel and let sit for 5 minutes  Tested small area first.
Cleaned off with warm soap and water
Applied thin film of GooGone sectionally then using a heldheld orbital buffer with terry cloth bonnet
I applied a small amount of NOVUS #2 fine scratch remover (The container store $6.00) to center of bonnet and got after it dividing the front of w/s in quarters.  After doing this twice, front and back ob
viously, it literally restored it to about 95+%.  I am very pleased with these results.
Cover the bike with old sheet or something to facilitate ease in cleaning up.
Blessings,
Woody
« Last Edit: September 09, 2013, 06:28:00 PM by Christbiker » Logged
HE>i
art
Grants Pass,Or
Grants Pass,Or
« Reply #1 on: September 09, 2013, 09:52:25 PM »
Why the googone? Did it take off the protective coating? My shield has some of the coating missing in small areas and it cannot be polished
dubsider
Flat6 baby #33034
Dublin GA
« Reply #2 on: September 10, 2013, 04:44:57 AM »
what I found to best care for my WS (Memphis Fats)... is Lemon Pledge.  and for that matter the paint and chrome as well. It also fixes up hard water spots on my vehicles..
« Reply #3 on: September 10, 2013, 04:48:31 AM »
I've heard pepsodent or colgate toothpaste works also, but have not tried it personally.
Raverez
No good deed goes unpunished
Central New York State
« Reply #4 on: September 10, 2013, 07:15:39 AM »
Kind of like the fix for foggy headlight lens on cars. I wonder if some of those products will work on the w/s?
Pappy!
Central Florida - Eustis
« Reply #5 on: September 10, 2013, 06:55:51 PM »
Well, maybe.....oh never mind! Lets just say you left yourself wide open on that one !!
Bigun
VRCC# 32964
Monroe, Iowa
« Reply #6 on: September 11, 2013, 05:12:33 PM »
This Is what I use on mine and it is as clear as new. Also used it on my old 81 Wing winshield went from unsafe to like new after a few applications.
1999 Valkyrie Interstate
« Reply #7 on: September 12, 2013, 05:43:57 PM »
In case you didn't know, tooth paste (not the gell) is made from rock. So it is a very fine abrasive. Fine enough it will remove the UV damaged plastic on your lens (or windshield), with out scratching it.
