November 25, 2025, 09:54:49 PM
Are there any on bike arc welding precautions?
Topic: Are there any on bike arc welding precautions? (Read 1103 times)
phillipabailey
September 13, 2013, 04:21:59 PM »
I work on Mack Trucks for a living and before welding on them we are supposed to unhook all the batteries and unplug all the control modules. Are there any preliminary precautions before mig welding on a 98 Standard?
Tropic traveler
Silver Springs, Florida
Re: Are there any on bike arc welding precautions?
September 13, 2013, 05:14:31 PM »
Done several welds on several Valks, never unhooked anything. No problemos at all.
Snap-on 115V MIG.
'13 F6B red for Kim
pancho
Bonanza Arkansas
September 13, 2013, 05:20:05 PM »
I would take the same precautions you take on the Mack trucks,,,, it only takes one damaged ignition control module to make you wish you had taken the two minutes to unplug it.
Michvalk
Remus, Mi
September 13, 2013, 05:28:00 PM »
I would at the very least, disconnect the battery completely, and make sure the leads are not touching anything. Unpluging the ICM is not a bad idea either. So few minuets, lower the risk
Trynt
So. Cen. Minnesota
September 14, 2013, 08:11:50 AM »
I've been told that you should avoid having a bearing between the ground and the striker, because it is possible to pit the bearing.
September 14, 2013, 09:25:02 AM »
I too would recommend unplugging anything electrical you can and not allow any welding current to go through a bearing.
pancho
Bonanza Arkansas
Reply #6 on:
September 15, 2013, 05:19:52 AM »
Quote from: Trynt on September 14, 2013, 08:11:50 AM
Good point, certainly something to be aware of!!
crow
Toujours Pret
Citrus Co Fla
Reply #7 on:
September 15, 2013, 04:54:04 PM »
ALWAYS... ground as close to the weld as possible
Last Edit: September 15, 2013, 04:57:10 PM by crow
that your ass cant cash
58Woody
Chanhassen , Mn.
Reply #8 on:
September 16, 2013, 04:37:02 AM »
Yes , if you ground close to the weld, you will be fine.
The electrical takes the path of least resistance. therefore you will not be sending "juice" through the bearings or electrical components.
Be not afraid. Only believe.
=> InZane XXV
