November 25, 2025, 09:56:45 PM *
Author Topic: OIL LEAK, WHERE ?  (Read 866 times)
HH1628
« on: September 14, 2013, 01:57:44 AM »
MY 98 HAS AN OIL LEAK ON THE 2 EXHAUST MANIFOLD BOLTS IN THE LEFT FRONT  CYLINDER AS THE BIKE IS PARKED.  THE ENGINE BOTTOM IS CLEAN AND DRY. THE SHIFTER SHAFT, FARTHER BACK IS DRY ALSO. THE EXHAUST HAS NO LEAKS AND IS QUIET. THE SPARK PLUG IS CLEAN AND NORMAL. WHAT COULD CAUSE THIS ?
THANKS !
saddlesore
« Reply #1 on: September 14, 2013, 05:26:10 AM »
Did you check the seal around the shifter shaft?
http://www.valkyrieforum.com/bbs/index.php/topic,50964.0.html
DARE TO BE DIFFERENT
« Reply #2 on: September 14, 2013, 05:58:17 AM »
Take a close look at the intake runners where they connect to the head. After years of use, the o-rings in there have a tendency to leak and will ooze gunk that looks much like oil. If real bad, it could possibly run down the head. Or, could just be a small leak in the bottom of the valve cover or one of the cover's bolts. Don't torque those bolts down, they have a tendency to snap.
eric in md
« Reply #3 on: September 14, 2013, 06:10:57 AM »
also fork seal maybe ?
