November 25, 2025, 09:56:48 PM *
Author Topic: Question About Truck Stack Install  (Read 819 times)
dan7uk
Louisville, Kentucky
« on: September 14, 2013, 05:43:09 AM »
Ordered 18" miter truck stacks from Air Flow.  Will I have to remove the entire exhaust or can I just remove the tips and slide the new ones on?  Are the screws needed?  Thanks
« Last Edit: September 14, 2013, 06:10:15 AM by dan7uk » Logged
« Reply #1 on: September 14, 2013, 05:54:21 AM »
No need to remove the exhaust. As for screws needed, guess it depends on how tight they fit. If you have to drive them on I'd say no srews needed. My truck stacks are full lenth so it was not an issue.
signart
Crossville, Tennessee
« Reply #2 on: September 14, 2013, 06:02:19 AM »
You will probably want to put a couple screws in each side. Just transfer measurements from your oem tips. A little trickier to do with slash cuts, as you will need an accurate reference point to get them both the same.
« Reply #3 on: September 14, 2013, 11:16:49 AM »
What he said.  Just take off your old factory tips a save the screws.  You'll need to drill two mounting holes in the 18" Airflows.
Transfer the holes from the old tips to the new ones......measure once, twice and three times.   Wink
