February 08, 2026, 10:24:01 AM *
Author Topic: starter relay plug .. somebody posted no long ago help  (Read 1572 times)
eric in md
« on: September 15, 2013, 07:04:26 AM »
somebody posted the  oem starter relay plug i cant find it now ..  thanks for helping out
Thunderbolt
Worthington Springs FL.
« Reply #1 on: September 15, 2013, 08:29:44 AM »
RJ has that somewhere.  PM him and I am sure he will share the info.  I can't seem to find it right now either.
IamGCW
727 hood
« Reply #2 on: September 15, 2013, 09:12:19 AM »
Maybe here.
http://www.cycleterminal.com/motorcycle-connectors.html
Gil
Gil
Thunderbolt
« Reply #3 on: September 15, 2013, 09:43:35 AM »
Starter Relay Repair
Relay Part # 35850-MT4-000
 Wire loom repair kit - Part # 32110-ML8-305
This repair kit is actually for a 84-87 Gold Wing.
In the kit you get the following parts.
 Connector Assy. Not like original but will work
 Solder
 Shrink tubing
 Switch cover. - MUCH larger than the original.
The old one covered up the 30 amp fuse for protection from the elements.
This repair kit has a much larger boot that covers almost all of the starter relay and the connector.
You have to move 1 wire in the connector to the correct slot. It is the big red one, main wire. Move it to the empty slot and everything plugs in as before..........
« Reply #4 on: September 15, 2013, 10:00:11 AM »
Thanks Thunderbolt, ya did a good deed for me.   LOL
I think I still have the picture I originally posted.   Will have to look.
This is what is included in that parts package.
Here is the part # for the above package.
eric in md
« Reply #5 on: September 15, 2013, 05:22:43 PM »
 thanks guys .. just what the doctor ordered.
RedValk
Titus, AL
« Reply #6 on: September 18, 2013, 08:44:40 AM »
my 97 Valk quit a couple of weeks ago....and when i turned on the key, there was NOTHING...no lights, no power, no nothing. I trouble shot down to the starter reelay area....and when i checked it, i found the connector was melted/toast...the 30 amp fuse also melted/bad. As a temporary fix, i clean things up as BEST i could (it was a REAL mess)....and taped the heck out of everything. That got me back on the road.
I ordered a new reelay from amazon (for $10.50...instead of the 30-40 Honda wanted)...and then...the real challenge, finding a new connector. Not wanting to replace the WHOLE wiring harness...and not liking the "similar" connector mentioned in this thread earlier (the older Gold Wing connector that WILL work, but isn't the same)....i went on a search. I found this EXACT same connector on Ebay and ordrered it. It's coming from China. I ordered over a week ago...and have been tracking it. It left China...came to Chicago...and is coming in USPS this week. I SHOULD have it in time to do the "proper" fix this weekend. It has enough wire to splice into the existing wiring harness...with the correct connector.  It was $15.95
Ebay link:
http://www.ebay.com/itm/300818976813?item=300818976813&viewitem=&sspagename=ADME:L:OU:US:3160&vxp=mtr#ht_1614wt_1161
it also comes with a cheaper reelay. I'm not going to use that reelay...but will use the one i got thru Amazon that looks like the Honda original one.
here is the Amazon link for the $10.50 reelay I will use with this connector (even though my current reelay works, it looks pretty rough on the connector part too)
link on Amazon:
http://www.amazon.com/gp/product/B007473OWI/ref=oh_details_o02_s00_i00?ie=UTF8&psc=1
RedValk/Tim
Titus, AL
john
tyler texas
« Reply #7 on: September 18, 2013, 09:02:20 AM »
         mine did that (burn) 4/5 years ago ...     Shocked
          cut and scraped all the melted plastic off the plug and relay ...    Undecided
          cleaned everything under the cover ... all connections
           battery cables off too , bad ground at frame .    ???
            use dielectric grease to reassemble ...    cooldude
      like a scared rabbit           cooldude
vrcc # 19002
