January 29, 2026, 02:13:11 AM
Loss of power...
Topic: Loss of power... (Read 1762 times)
DaveD(MI)
'99 Interstate
Michigan
Loss of power...
July 12, 2009, 09:01:24 PM »
99 I/S, Just had the carbs synced and valves adjusted. Dragonpacks exhaust with brand new stock air filter. mobil synthetic motorcycle 10W-40, 11,000 total miles. Can't figure it out, just seems like it doesn't have the get up and go like it did a few years ago. Can barely stay ahead of the new Harelys. Clogged fuel filter? Ran a tank of seafoam about 1000 miles ago. Any thoughts?
Thunderbolt
Worthington Springs FL.
Does it seem to have a miss?
July 13, 2009, 04:12:36 AM »
take a sheet of paper large enough to cover the exhaust tip and hold it over the tip while engine is running one side at a time. If all three on that side are firing, you will notice that the paper will be held out by the exhaust pulses in a rhythmic pattern. If a cylinder is not firing, the paper will drop to the tip occasionaly. If you find that you have one not firing, either a plug on that side may be fouled, or the low jet may be clogged.
Is the tank vent tube kinked allowing the tank to build up a vacuum? When you stop and open the filler lid, does it pull air in with a whoosh sound?
Daniel Meyer
The State of confusion.
Re: Loss of power...
July 13, 2009, 05:34:03 AM »
Make sure the petcock is working correctly. A blown or partially blown diaphram will cause all kinds of symptoms.
CUAgain,
Daniel Meyer
