February 07, 2026, 06:36:16 PM *
Author Topic: Clutch assembly confusion  (Read 1062 times)
elpaso jo
Meath Co. Ireland
« on: September 17, 2013, 08:13:24 AM »
Hi Guys,
I am trying to figure out the assembly of my valks clutch, and reading instructions from the manual I quote,Disc B, (first disc on clutch centre) has no identification notches and disc A (installed after damper plate) has 3 notches, fine, I understand lining up the (O) marks with pressure plate and clutch centre and alternating the clutch discs and clutch plates, BUT, they say in manual that clutch B has no identification notches, but they have, some have one and some have two. Does it matter what way the rest of assembly are fitted providing, the first 3 are correct, and if so what position do i place the notches. OR do i have the wrong clutch discs. Please please advise.Ps I hope this makes some sense to you all.
chrise2469
Winnipeg Manitoba Canada
« Reply #1 on: September 17, 2013, 12:18:01 PM »
The B disc  has larger tabs and is labeled as 425.
The A disc has 3 notches in the tabs and is labeled as 825A on the tab.
After making sure the damper is aligned with the o, and after the first A,the rest alternate steel plate and clutch disc.  All the teeth will have to be aligned when you line up the disc tabs in the clutch basket.  The damper plate is the only one you have to align.
Hope this helps
« Last Edit: September 17, 2013, 01:13:27 PM by chrise2469 » Logged
elpaso jo
Meath Co. Ireland
« Reply #2 on: September 17, 2013, 02:32:04 PM »
Thank you Chrise, I am looking at them as I type and you are perfectly right.
That is a much clearer instruction than the manual gives me,
Much obliged
Joe
elpaso jo
Meath Co. Ireland
« Reply #3 on: September 17, 2013, 02:43:02 PM »
Hi ChrisI wont be getting to do the job for a week and Im not sure how to save your instructions and photos.
Do you think you could e mail me that reply and photos
m.joe.oconnor7@gmail.com
« Reply #4 on: September 17, 2013, 03:36:15 PM »
Just go to this post when your ready to do the job. Go to your profile and select show posts and find this one, then you can refresh your memory of Chris said.
« Last Edit: September 17, 2013, 03:39:00 PM by salty1 » Logged
My rides:
elpaso jo
Meath Co. Ireland
« Reply #5 on: September 17, 2013, 03:41:25 PM »
Thanks a a lot guys for your help much appreciated
« Reply #6 on: September 17, 2013, 04:22:45 PM »
Or click on the add bookmark tab at the top or bottom of this page (next to the reply tab) to bookmark this post.
