February 07, 2026, 06:30:19 PM
Need advise why exhaust note is louder?
Topic: Need advise why exhaust note is louder? (Read 1464 times)
dan7uk
Louisville, Kentucky
September 23, 2013, 04:17:43 PM »
Replaced my oem exhaust tips with Air Flow 18" slash cut truck stacks. My pipes are unmolested factory still has the piggy's. I've notice the exhaust note is louder since I've installed the stacks. Don't understand why extending the tips about six inches would make it louder. From the piggy's to the manifold is the same, can someone explain why?
Moonshot_1
Re: Need advise why exhaust note is louder?
September 23, 2013, 04:39:18 PM »
I'll take a crack at it.
It probably isn't any louder. The sound waves simply have a more direct line to your ears as they are no longer obstructed by saddlebags, a tire and other parts of the bike as the sound exits your pipes.
Mike Luken
Cherokee, Ia.
dan7uk
September 23, 2013, 04:42:14 PM »
Forgot to mention it's a 99 tourer with oem hard bags.
Bone
September 23, 2013, 04:42:31 PM »
It changed the tone of the note.
It's now easier to hear you know like when a person doesn't hear his wife.
Tropic traveler
Silver Springs, Florida
September 23, 2013, 05:17:37 PM »
Classic case of droning into an echo chamber.
Had a similar problem with my glass pack mufflers dumping the sound into the longer tips.
Fixed it by extending the exhaust dump to the end of the tip. No more echo chamber effect.
'13 F6B red for Kim
Rio Wil
September 23, 2013, 06:26:25 PM »
Same effect as playing music through a 1 inch tweeter or a 4 inch speaker. Then sound pressure pulse came out the 1 inch piggie and directly in to the atmosphere....ie a 1 inch tweeter. With an extension covering the piggies and making the sound pulse travel further before entering free air, it allows the sound pulse to expand to 4 inches and slow the pulse down thereby enlarging the pressure wave front lowering the tone .
Farther
Quimper Peninsula, WA
Reply #6 on:
September 23, 2013, 07:07:35 PM »
Just like using a megaphone.
~Farther
