February 07, 2026, 06:30:17 PM *
Author Topic: Truck stack exhaust  (Read 1509 times)
jdp
« on: September 23, 2013, 06:57:55 PM »
Ive read all the post on cutting and welding the baffles, but can I just slide the 36 inch stack over the stock baffles? And what is the advantage on cutting the baffle and mounting it on the end of the stack?
« Reply #1 on: September 23, 2013, 07:02:57 PM »
You can just take the oem covers and tips off and add the truck stacks. Most people cut the rear baffles out to make it louder. I dont know about cutting the baffle and putting it back on the end of the stack. Seems a whole lot easier to leace the baffle in place and just slide the stacks over. I knoe I kept my rear baffle in cast I want to slide them in on long trips to quiet it down a little.
jdp
« Reply #2 on: September 23, 2013, 07:36:06 PM »
Ok thanks for the reply, I think I'll just slide the stack over my stock baffles,thanks again
« Reply #3 on: September 23, 2013, 07:43:42 PM »
ShopTalk is your friend......
http://www.valkyrieriders.com/shoptalk/truckstackinstall.htm
To answer your first question, no, you do not have to remove the rear baffle section to install truck stacks.
The basic idea behind cutting off the rear of the exhaust can, ie, rear baffle section, is so that one can have a louder exhaust.
As in Rio's idea, you can reinstall the baffle section when one wants a quieter exhaust.
It's the same idea behind MarkT's silencers.  Take 'em out when you want loud, put 'em back in when you don't.
Alot of folks gut or take out the rear baffle section only to find out that the newly induced drone drives 'em nuts.
That's the idea behind putting the baffles back in.
jdp
« Reply #4 on: September 24, 2013, 12:54:24 PM »
Yeah thanks,I just got my new truck stacks and alittile afraid to cut them for the mounting bracket,they look soooo good,but thanks for filling me in on the baffles
