February 07, 2026, 06:36:15 PM
Progressive Bushing sleeve problem
Topic: Progressive Bushing sleeve problem (Read 1186 times)
westsidevalk
West Springfield, MA
September 23, 2013, 07:05:11 PM »
I recently inserted the metal sleeve that goes inside the lower shock bushing for my 99 Tourer.
I used a C clamp to fit it, it seemed okay but I cant get the shock to slide into the lower mount. Not sure why.
It fits almost in but its too wide. I wonder if the metal sleeve is too long..not sure why it wont fit.
The bushing inside got pushed out a little trying to get the sleeve in, but not too badly.
Any thoughts are welcome. I hesitate to use too much force cause Im good at breaking things that way.
Re: Progressive Bushing sleeve problem
September 24, 2013, 08:25:01 AM »
Probably would have been good to check the sleeve fit before hand.
Now it will be harder.
I wouldn't just go slamming the shock into the holder.
It'll take some ingenuity to work it out correctly.
Get a bigger hammer.
September 24, 2013, 09:45:16 AM »
To remove them in the past, I used a couple sockets. One large enough to fit over the sleeve, one small enough to match the diameter of the sleeve. Put it in a vise and slowly crank down on it. It will push the sleeve out into the larger socket.
