shortleg
« on: September 27, 2013, 02:42:52 PM » |
What size fuel line do I need 3/8 or 5/16 Shortleg[Dave]
sawdustar
« Reply #1 on: September 27, 2013, 03:55:44 PM » |
5/16" will be a snug fit and 3/8" could be enough to truly require a clamp to hold it in place. Heck, I'm new here...so what do I know.
Thank You, Dennis
pocobubba
« Reply #2 on: September 27, 2013, 05:04:15 PM » |
Dave , I used 5/16 when I did my desmog because of the tight fit. I don't notice any problems with fuel restriction . If you go to the dealer or check on line you can get the proper metric size.
Pocobubba {David}
Tropic traveler
Silver Springs, Florida
« Reply #3 on: September 27, 2013, 06:49:40 PM » |
8mm. Check around, it's available.
'13 F6B black-the real new Valkyrie Tourer '13 F6B red for Kim '97 Valkyrie Tourer r&w, OLDFRT's ride now! '98 Valkyrie Tourer burgundy & cream traded for Kim's F6B '05 SS 750 traded for Kim's F6B '99 Valkyrie black & silver Tourer, traded in on my F6B '05 Triumph R3 gone but not forgotten!
« Reply #4 on: September 27, 2013, 07:11:36 PM » |
8mm. Check around, it's available.  Isn't 8 mm 5/16?
I can't help about the shape I'm in I can't sing, I ain't pretty and my legs are thin But don't ask me what I think of you I might not give the answer that you want me to
Tropic traveler
« Reply #5 on: September 27, 2013, 08:38:04 PM » |
8mm. Check around, it's available.  Isn't 8 mm 5/16? Very close but just enough difference to feel it on a barb style fitting. 5/16 goes on a bit hard while 3/8 slips over an 8mm barb fitting fairly easy.
etiwandablues
« Reply #6 on: September 28, 2013, 10:39:38 AM » |
8mm is a touch larger at 0.3150 in versus 0.3125 in for 5/16
« Reply #7 on: September 28, 2013, 03:11:24 PM » |
Use some 5/16" and spray some alcohol on the fitting before trying to slip it on. Makes moving rubber on metal move real slick, dries with no residue.
Roadog
« Reply #8 on: September 29, 2013, 06:00:57 AM » |
one mm is .03937 , 8 mm is exactly .31496 so yes slightly larger than 5/16 @ .3125 or 2.4 thousandths . Dont know how you could tell any difference.
